Go Back   Automotive Forums .com Car Chat > Renault > Clio/Clio II/Clio III
Old 04-11-2006, 12:05 PM   #1
ben_p
Fitting a Rev Counter to a P reg / 96 Clio 1.2 RL
I've got a P reg (96) Clio 1.2 RL (D type engine).
I bought a rev counter / tachometer like this one:
http://cgi.ebay.co.uk/OFFICIAL-FAST-...QQcmdZViewItem
Unfortunately I'm having trouble installing it. The instructions say that you need to connect one of the wires to the coil, but my model of Clio doesn't have a regular coil (because it is fuel injected?).
Does anyone know where I can wire up the rev counter to the signal (for the distributor?)
Sorry about the vagueness, I don't know much about engines.
ben_p is offline   Reply With Quote
Old 05-22-2006, 02:15 AM   #2
Eben
Re: Fitting a Rev Counter to a P reg / 96 Clio 1.2 RL
I bought one to, only to find out its not easy to fit, you have to take apart the dash just to get to the cluster area where you could find the signal cable..
So I just sold it, not going through all that trouble
Eben is offline   Reply With Quote
Old 09-21-2006, 02:38 PM   #3
ben_p
lol yeah i was thinking about selling it anyway & getting a turbo diesel, can't afford to do that for a bit though and the car is in really good nick (went straight through the last mot). Glad it did - I spent over £1000 in a new exhaust, brakes, starter motor and more in the last year or so.
So I think I'lk keep the car for another year or so, it would be nice to have a rev counter in the meantime though.
Do you remember what the signal cable looked like? What part if the dash did you have to take about?
Thanks for your help,
Ben
Old 09-21-2006, 02:49 PM   #4
Eben
Ben
I got the 1.5 DCI, boosted to 1.4 Bar...hehe
Loveley car and light on fuel
Old 05-26-2009, 05:31 PM   #5
lenny 1
Post Re: Fitting a Rev Counter to a P reg / 96 Clio 1.2 RL
hi ben this is very simple just remove dash board and pull out insturment display look at the cluster on the back of fuel gauge connect sender wire to number 7 pink wire make sure that you have good ground &live witch you should be able to get from spare black&red&white leads located on dash above radio this will defintly work as just completed for my son good luck lenny
lenny 1 is offline   Reply With Quote
Old 03-08-2010, 10:58 AM   #6
alz2k8
does anyone remember if the wire is on a blue conector block? thanx
alz2k8 is offline   Reply With Quote
