Go Back   Automotive Forums .com Car Chat > Subaru > Legacy / Liberty / Baja
Old 04-14-2010, 10:48 PM   #1
tony2soon
Help '93 Legacy 5sp won't start after checking OBD1 Codes
1993 Legacy AWD. About a week ago I started seeing a CHECK ENGINE LIGHT after starting the car, it went away after 5minutes or so. I decided to try reading the OBD1 codes. With the key in the off position I connected the 2 green self diagnostic connectors under the drivers kick panel and turned the key to the on position (engine off). The cooling fans started turning on then off repeatedly I also heard a few relays cycling. I observed a solid CHECK ENGINE LIGHT, not flashing the OBD1 code as I expected. Well no luck here so I turned the car off disconnected the self diagnostics and tried to start the car, nothing happened, didn't even try to turn over, no clicking, no sounds what so ever.
I did check the starter and it seems fine and it had not given me trouble before. I shorted the solenoid on the starter and the car fired right up though running a little rough. Turned the car off and I cannot start it again with the key, only if I short the starter again. What gives? Did I manage to do damage just by trying to read the OBD1? Anyone had this type of problem before? Please help.
Thanks
Tony
tony2soon is offline   Reply With Quote
Old 04-15-2010, 08:13 AM   #2
RahX
Re: Help '93 Legacy 5sp won't start after checking OBD1 Codes
Make sure you didn't pull any connectors apart when you were under the dash. Sounds like you might have disturbed something.
RahX is offline   Reply With Quote
Old 04-18-2010, 12:20 PM   #3
tony2soon
I found the problem!! When I removed the kick cover the tiny chip (key) that engages the starter cutout sw (anti-theft option) fell out as I moved the kick cover to the side (starter cut out sw is attached to the kick cover). I saw this but I didn't know what this was. Anyway now that it is back in place I can start up again.
