Go Back   Automotive Forums Car Chat > Volkswagen > Beetle - New/New Beetle Convertible
Old 04-15-2009, 02:17 PM
KennyI KennyI is offline
'99 New Beetle Door Ajar Sound
My 1999 Beetle has developed an annoying problem with the drivers side door. Every once in awhile (sometimes random, and sometimes after hitting a bump) the door ajar warning sound turns on. The door is closed firmly at this time. I have tried to fix it by adjusting the strike plate so the door is closed "more" but that did not solve the problem. I can stop the warning sound by pulling the door handle inward when I am seated. A pain in my... Please help if you can.
Old 04-23-2009, 11:45 AM
erik77 erik77 is offline
Re: '99 New Beetle Door Ajar Sound
hi, i have a similar problem, do you speak spanish? el problema esta en uno de los microswitch que lleva la cerradura, hay que desarmarlo, y cambiar ese microswitch, es el que esta en contacto con el poste de la puerta, ese switch tambien ocasiona que a veces no se active la alarma, o que al activar la alarma, no baje el seguro de la puerta del conductor
Old 04-23-2009, 03:00 PM
SC2ner SC2ner is offline
the problem this in one of the microswitch that carries the lock, one must disarm it, and to change that microswitch, is the one that this in contact with the post of the door, that ignition tambien causes that at times itself be not activated the alarm, or that upon activating the alarm, descend not the insurance of the door of the conductor
Free translations are nice. The microswitch is built into the door latch. Basically the locking mechanism. You have to replace the latch. It's a common issues on the beetle, golf/gti, and jetta. Basically they all share a lot of the same parts, but the body is different and some things are different (window regulator, lights, switches, and so on).
Why are you trying to act hard as hell,
when you know damn well
you don't wanna feel the shell
Old 05-10-2009, 08:06 AM
hako hako is offline
Check this link - it explains the problem and has a great picture of the latch mechanism....it is possible to replace just the microswitch for next to nothing.
http://newbeetle.org/forums/question...-problems.html
Good Luck.
Old 05-14-2009, 10:04 AM
You cannot get the micro switch separate. It's built into the latch. Only way it comes.
Old 05-16-2009, 04:03 AM
You're probably correct....but a generic one can be made to fit apparently. Here is another link which explains pulling the lock apart and diagnosing the actual fault...it's for a Passat but they are virtually the same. If you can fix it yourself you save a couple of hundred dollars but you've got to like pulling things apart.
http://www.taligentx.com/passat/main...lockmechanism/
Tags
99 beetle door ajar
