Old 04-28-2009, 12:54 PM
Collins18tol Collins18tol is offline
Post Prelude 2.0s
What would be a easy swap for this engine it is the duel side carbs and i am looking for more power, this stock engine is a turtle , what would be the easiest engine to put in?
[email protected]
Old 04-30-2009, 11:14 PM
H23A1Lude H23A1Lude is offline
Send a message via AIM to H23A1Lude Send a message via Yahoo to H23A1Lude
Re: Prelude 2.0s
What engine do you have now? I need the engine code, and what ECU you have, and what year Lude you have.
1994 Honda Prelude Si H23A1
Me: Get new U-Joints, then your Ford won't suck as bad.
Him: Do I need o-rings?
Me: No you idiot.
Him: Sorry, I've never replaced an O-Joint before
Me: FAIL
Old 05-01-2009, 12:39 PM
Re: Prelude 2.0s
1988-1990 2.0S, the B20A3 which is a SOHC 12-valve dual-sidedraft carburetor engine displacing 1958 cc that produced up to 104 hp (78 kW) and 111 lb·ft, those are all the engine specs i have
Old 05-02-2009, 12:55 PM
Re: Prelude 2.0s
If you want a swap, go for an H22. Check out preludepower.com, look around. Azrace+machine recently made H22 mounts for this car.
An H22 is something like 20 pounds heavier than the B20. And it sits really far back in the engine bay.People have done a b16/b18 head swap. From what I understand, it's the same thing as an LS/Vtec, but you have to move/create 3 bolt holes. However, this isn't as beneficial as you think. These motors have a very strong tendency to throw a connecting rod(#3, usually) if revved over 7000. And that's just a pain in the ass. So you'd need custom cams for the head as well. You could also boost the B20. People are running 300+ on stock sleeves, they have thick iron sleeves from the factory, and stock internals can take 220 at the wheels, 240 with a perfect tune. But boost always has its problems. IMO, I'd do the H-Swap.
Me: No you idiot.
Me: FAIL
