Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 11-26-2001, 04:45 PM
max96ima max96ima is offline
car is runnig very bad help
I changed the clutch and cleaned the throttle body and now the car runs
bad. Code says it is a crankshaft sensor (postion) and knock sensor
the car will hesitate at about 3200 rpms and when I come to a stop
the cars rpms goes all the way to 100 rpms and then creeps back up.
can the crankshaft sensor do this if it is bad
are maybe the somthing went bad in the throttle body cleaning.
please help my baby is sick
Old 11-26-2001, 06:11 PM
Ravq Ravq is offline
Did you remove your MAFS to do the throttle body cleaning? Your variable rpm symptoms could be due to a damaged or broken MAFS. It can be checked using a mulitimeter. And have you checked the battery? A weak battery can cause DTC 0802 - Crankshaft position sensor.
Stillen kit & grill, Stillen Type II spoiler, KYB AGX/Progress, 19x8.5 ADRs w/Toyo Proxes FZ4s, ...........
Old 11-27-2001, 12:04 PM
mtrai760 mtrai760 is offline
Send a message via AIM to mtrai760
The CPS seems to go bad at weird times for seemingly no reason. I'd take the car into Nissan and have them check the voltage, it might not be cheaper, but less of a hassle than trying to get a FSM and voltage meter to check it yourself. They can hook it up to a machine and tell you exactly what it's doing. Good luck.
5spd VLSD
15.2@92mph
180hp & 193tq
Faster than jOO!
A hunting we will go...
Old 11-27-2001, 05:09 PM
well I bought a new sensor ($100) and installed it and guess what the problem went away. thank god
thanks for all the help you guys gave me
Old 11-28-2001, 10:36 AM
Nizmolee Nizmolee is offline
Send a message via AIM to Nizmolee
i changed the tps sensor which wasnt the problem on my case. i messed up my aif flow meter. Learn from experience, dont put an oiled intake back on the vehicle if its not dry or it will damage the unit.
98 Auto NOS Maxima.
Old 03-29-2003, 11:54 AM
pollochicken pollochicken is offline
Which sensor did you say you replaced and fixed your problem? the knock sensor?
Old 03-29-2003, 12:17 PM
DiS's Avatar
DiS DiS is offline
Send a message via AIM to DiS
Nizmolee !!!!!! woah You said DONT PUT OILED INTAKE on. What do u mean. Oiled Filter? I have Injen with K&N Oiled filter charger. Will I have problems?
97 Nissan Maxima GXE
Auto Trans
Red Injen Racing Division CAI with K&N FilterCharger, Zero1Racing Front Strut Bar
DaRk GrEeN/Beiege Interior
Cleared out taillights/Clear fronts/rewired blinkers and sidemarkers, upgraded grounding...Check my Pics out on my homepage
New purchase BRAND NEW '03 Mazda ProtegE 5-spd
_________________________________________________
Maximum Respect To MaxiManiacs and all Nissan 0wn3r$
