Go Back   Automotive Forums .com Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-05-2009, 04:54 PM   #1
Hijyackle
Hijyackle's Avatar
89 formula dash light problem
i have no gauge illumination...a few days ago i was driving at night and when i hit the high beams the dash went dark....the 5 amp fuse was blown so i changed it...it worked for about 30 seconds then blew the fuse again so i put a 10 amp fuse instead of a 5 and it worked for about 30 secs again then went dark but didn't blow the fuse...please help me
"In order to change the world you have to get your head together first" -Jimi Hendrix
Hijyackle is offline   Reply With Quote
Old 04-05-2009, 05:27 PM   #2
Morley
Re: 89 formula dash light problem
NEVER put in a higher amp fuse in a circuit that keeps blowing fuses...You probably burned a wire since you said the fuse didn't blow.
One of the common places for a short is atthe EGR solenoid connector..this is wired to the gauge fuse circuit.
Morley is offline   Reply With Quote
Old 04-05-2009, 09:26 PM   #3
Hijyackle
Hijyackle's Avatar
i know it was a bad plan but i ran out of 5 amp fuses....i took the dash apart and the lower panel had a burn mark in the foam at the base of the steering column on the right hand side if your sitting in the driver seat
Old 04-07-2009, 07:43 PM   #4
Hijyackle
Hijyackle's Avatar
so a little update i replaced the green wire running from the headlight switch to the fuse box and i must not have used a high enough gauge wire cause it caught on fire and shot flames out my driver side vent...I'm waiting for it to warm up so i can tear into it...good thing i have a few parts cars
Old 04-08-2009, 09:51 AM   #5
wrightz28
is bring'n sexy back
wrightz28's Avatar
Did you install the correct amperage fuse?
wrightz28 is offline   Reply With Quote
Old 04-09-2009, 04:32 PM   #6
Hijyackle
Hijyackle's Avatar
i did...the fire was from the headlight switch...the brightness knob melted (not the wire i installed) so ill replace that when i get paid
