Wheel bearing going ?
I have this sound which seems to be coming from the front wheel(s). Hard to describe the sound but I would guess a wheel bearing, truck is at 177,000 miles now. I jacked it up and rotated the front wheels but couldn't hear/feel anything unusual. What's the best way to find out if the wheel bearing is bad ?
Bert 2000 1500 Z71, 5.3 ext. cab, long bed. |
Re: Wheel bearing going ?
Do you notice a change in sound when during a corner? If so, when you turn left the right wheel bearing bears the load and vice versa.
You could jack front end , remove wheel, caliper and rotor to see if you have any play when you try moving the hub by placing hands at 12 oclock and 6 oclock and see if you have any movement in bearing and turn hub slowly to feel for rough spots. Hope this helps |
because of the design used in this vehicle any wheel bearing failure will cause abs/braking problems very quickly.....
since you also have leaking front dif problems of an unknown amount... I would say the front dif may be damaged and need be overhauled /replaced |
#4 | ||
Bert
My Truck: 2000 Silverado,, Z71 5.3 Ext. Cab, Long Bed Original motor + transmission! As of 3/21/14, I'm at 266,300+ miles! My wife's Truck: 2005 F150 Lariat CrewCab (Way nicer them my truck!) |
![]() Join Date: Sep 2004
I have a 99 silverado z71 ext and had a whining sound from my front end at 35 mph and up. Turning left to right had no effect on the sound or pitch. I also had a leaky drivers side differential seal. When I replaced the front driver seal, I pulled the caliper and then turned the wheel bearing. I also went to the auto parts store beforehand and tried turning the new bearing. My original bearings had a slight rubbing sound (sounded like a rubbing brake pad), there was absolutely no movement from 12 to 6 movement. I replaced both from az (Timkens) $119 a piece and there was a 100% percent improvement. They are now both replaced and no sound at all from the front. Front driver seal was pretty easy to replace also. I would do both while I had the truck torn down to that point. Just my 2 cents. Hope this helps.
forgot to mention, I changed them out at 148,000 miles. Nice tuck, I have the same but a 99 and short bed.
Tell us what you found to be the problem.. |
#7 | |
Get up to about 35-40 mph on a OPEN road and swerve left and right. If you notice that the sound gets quieter one way more than another it will tell you what bearing is bad. They get quieter when there is a load on them so when you turn right the weight is on the left and visa versa. Post back what you find.
ASE Master Certified before the age of 20 Current Cars: 2001 Chevy Silverado 1500 Z71 5.3L 1996 Acura Integra LS B18 1.8L Past Cars: 1990 Buick Estate Wagon 5.0L 1987 Chevy S10 2.5L Tec Four 1995 Pontiac Grand Am 2.3 Quad 4 1996 Jeep Grand Cherokee Limited 5.2L AWD 1991 Ford Tempo L 2.3L 1992 Buick LeSabre 3.8L 1997 Buick Century 3.1L 1996 Lumina APV GT 3.4L 2006 Ford Escape 3.0L XLT |
#8 | ||
It's roughly $170 for the hub, a large socket rented from a parts store, and about 20 minutes "on your knees" labor. |
#9 | |
A noisy wheel bearing isn't always loose (but will usually feel rough turning it by hand), and a loose wheel bearing doesn't always make noise. The best thing to do is replace them in pairs (since they are identical left and right, and have very close to the same mileage on them). About 95% of the time, if you turn left and the noise increases, the right wheel bearing is bad (and vice-versa)
'04 Cavalier coupe M/T 2.2 Ecotec Supercharged 14 PSI boost, charge air cooler, 42# injectors Tuned with HP Tuners Poly engine/trans/control arm bushings Self built and self programmed progressive methanol injection system |
