Go Back   Automotive Forums .com Car Chat > Opel/Vauxhall > Commodore/VS/VT/VX
Old 09-28-2005, 02:47 PM   #1
I LOVE MY HOLDEN
Question BROWN FROTH AND OIL IN RADIATOR help???????
I Have A 94 3800 Acclaim Great Car But In The Radiator It Has A Brown Sludge Especially All Over The Radiator Cap Ive Been Told Its Normal By Some Other Sites But My Oil Level Has Decreased Slowly Please Any Ideas Be Great
I LOVE MY HOLDEN is offline   Reply With Quote
Old 10-29-2005, 03:43 PM   #2
wazza4678
Wink
this is not normal,there is a slight amount of oil entering the cooling system.this can come from............
a cracked head,or
a deteriorated head gasket,or
a corroded timing cover,or
a deteriorated automatic transmission cooler(which is built into the radiator tank)
report back if you need further help with testing
wazza4678 is offline   Reply With Quote
Old 04-13-2006, 12:18 AM   #3
stephen88
Re: BROWN FROTH AND OIL IN RADIATOR help???????
YOUR CAR IS FUCKED!!! who eva told you that is normal has no idea at all. this stuff in your radaitor is oil from your engine thats why your oil levels are slowly droping. you need a new head or gasket but get it looked at asap!!!!
stephen88 is offline   Reply With Quote
Old 07-07-2007, 07:25 AM   #4
vxwagon02
I have had 1 x VR Exc 1 x VS Exc & 1 x VS Berlina all with the same problem without dramas. The 95 Berlina had this problem from 60,000km(under warranty) until I just sold it at 285,000kms. I took it to a few Holden dealers over the years & it was cause by having more frequent coolant changes due to higher kms & the oil residue is from the pellets added to the coolant every change. If the coolant is not flushed properly the pellets (lube) material builds up in the system. Holden`s put in 3 pellets every change to ensure that all parts are lubed, so they won`t fail under warranty. I just done my first water pump after 280,000kms. I would not worry too much!
vxwagon02 is offline   Reply With Quote
Old 07-07-2007, 09:44 AM   #5
mmcleo11
mmcleo11's Avatar
The pellets are NOT a lubricant. They actually stop the waterpump and the rest of the cooling system from leaking. Once the powder from the pellets is wet, it stays in a liquid 'mud' form until a leak occurs and the pellet powder fills in the gap. As soon at it hit the air, it becomes a cement like power that stops the leak.
N14 Pulsar
VQ35 conversion with major N/A upgrades, 6 spd FWD manual HLSD
18" Rims, big brake kit, Coil overs and freshly painted
Smashed Black VY SS Ute
The workhorse...
Twin turbo 5.7L LS1
Boyd Coddington 19" Turbine Wheels
AP Racing 4 Piston Brakes
Tein Coil over Suspension
HKS EVC 6 Boost Controller
PLX Devices DM-200 OBDII
Custom Front Mount Intercooler
mmcleo11 is offline   Reply With Quote
Old 09-24-2007, 05:03 PM   #6
Club327
Yeah, the pellets are responsible for a lot of the sludge found in commodore coolant bottles etc, in the past. But no-one uses them anymore so the residue should be well and truly flushed out of the system. The head gaskets on the VR are not prone to failure! The intake manifold gaskets on the VR have a tendency to fatigue and fail, allowing water to seep into the engine. Not a big problem if it's a slow seep. But worth fixing. Have a look at the joints between the manifold and the heads - if you see any beeds of water, then the gaskets should be replaced.
Club327 is offline   Reply With Quote
Old 07-05-2010, 08:11 AM   #7
driffter
I agree with club327, try the inlet manifold gaskets first before anything else. The inlet manifold gaskets the V6 engine are junk, they always crack and weep oil into the cooling system. Also don't bother with those pallets either, there also junk
driffter is offline   Reply With Quote
