2002 Windstar. Where is pcm? Anyone do remote starter?
Looking for my pcm to get a tach signal wire, anyone tell me where it is? Also, anyone put a remote starter in one of these? I have PATS and a by pass module, no start though. Remote starter sayes it isnt getting a tach signal, {learning it}
![]() Join Date: Sep 2004
Re: 2002 Windstar. Where is pcm? Anyone do remote starter?
I don't have a remote starter, so I am of no help to you there.
The PCM is located IN the firewall.....on the passenger side. You access it from the engine compartment. On the passenger side engine compartment, look at the TOP.....up under the windshield wiper cowl.....kind of behind the top of the strut tower. There is a BIG wire harness plug there.....into the firewall. The wire harness is plugging into the PCM. As to what wire does what.....I only have access to that information for 1996 model year.....so I will leave that part to someone else.
Moderator for Ford Windstar room only Links to my pictures, intended as an aid, not a replacement for, a good repair manual. 1996 3.8L Windstar http://www.flickr.com/photos/4157486...092975/detail/ 2003 Toyota Sienna pictures (not much there yet) http://www.flickr.com/photos/4157486...781661/detail/ |
Try this, it is from 12volt.com, I installed a remote start in my 96 and went to the coil pack for the tach signal as is sugjested here for 99 to 02. Mine works fine but I did mot have PATS to deal with.
Ford Windstar 1999-2002 Remote Starter Wiring Colors and Notes Start: DK. GREEN IGNITION SWITCH HARNESS * Ignition #1: WHITE/YELLOW IGNITION SWITCH HARNESS Ignition #2: BLACK IGNITION SWITCH HARNESS Ignition #3: VIOLET/ORANGE IGNITION SWITCH HANRESS ** Accessory: BLACK/LT. GREEN IGNITION SWITCH HARNESS Brake Light: RED/LT. GREEN AT SWITCH ABOVE BRAKE PEDAL Tach Signal: DK. BLUE/LT. GREEN AT COIL MODULE *** Parking Lights: YELLOW/LT. BLUE (-) AT FRONT ELECTRONIC MODULE **** OEM Alarm Disarm: LT. BLUE/BLACK (-) 16. PIN CONN. LEFT OF STEERING COLUMN OEM Alarm Arm: ARMS WHENEVER THE DOORS ARE LOCKED. Notes: * These Vehicles May Be Equipped With Ford's PATS Anti-Theft System. Bypassing Transponder Theft Systems. ** Use Ignition #3 to Drive a Relay and Fuse the Constant +12 Volts of the Relay Seperately at Battery With a Separate 30 Amp Fuse. *** Located Top Left Side Of The Engine -------------------------------------------------------------------------------- Ford Windstar 1999-2002 Alarm and Keyless Entry Wiring Colors and Notes Constant +12 Volts: RED IGNITION SWITCH HARNESS Starter Kill: DK. GREEN IGNITION SWITCH HARNESS * Ignition +12 Volts: WHITE/YELLOW IGNITION SWITCH HARNESS Dome Lights/Superv: ORANGE/WHITE (-) AT FRONT ELECTRONIC MODULE **** OEM Horn: DK. GREEN/ORANGE (-) 8 PIN CONN. LEFT OF STEERING COLUMN Power Lock: LT. BLUE/ORANGE (-) 16 PIN CONN. IN DRIVER'S KICK PANEL Power Unlock: LT. GREEN/YELLOW (-) 16 PIN CONN. IN DRIVER'S KICK PANEL Trunk Release: SEE NOTE ***** Alarm Input Wire: ORANGE/WHITE (-) AT FRONT ELECTRONIC MODULE **** Notes: **** Located Behind Driver Side Dash Left Of Steering Column. ***** Sliding Door Operation Tan/Lt. Blue (-) At Switch (Same Color For Driver or Passenger Side). |
