99 T&C hard to start in cold but unstable idle and die out run ok in warm or hot days
Guys, I have 99 T&C for 9 yrs now and seems to be from summer i get this problem
#1 Once i had unstable idle and cuttoff after highway driving in august (warm month ) Check complite vacume system and gas line and return becuse of code Fix was clean IAC and put back added chevron engine cleaner (recomended by mechanic) work good then #2 soon as nov dec 2008 came proble came back unstable idle when cold, start car but not stay on till hold gas padle to keep it on fix was low battry cold crank amp ( was not an real issue)but considering chicago winter was wise thing to do ...problem not fixed then i search around and came accross this site ..good info intaligent people and appriciated fix narrow down to coil pack drop when extreamly cold days range should be 10900 to 14900 i got ok in 40F( 12000) but in cold -10 left it 2 hrs (new pack and old pack and measure resistence ...2 coil got around 109XX and one got 10700 Improoved idle but car was parked at 40F so unsure then got idle air control and put it in drive out and park out in cold for 6 hrs car started idle started with 1200 and slowly came down to 900 after 2 mint s specially thanks to RIP appriciated all forumes and i went thru about 30 diffrent to narrow down thanks again i will update if any thing changes |
Re: 99 T&C hard to start in cold but unstable idle and die out run ok in warm or hot days
Not sure what I did but, thanks for the thanks. While I'm at it a big thank you to you for passing your experience along. Hope your troubles are over.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds. **Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual. 07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan |
