Go Back   Automotive Forums .com Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 10-11-2007, 03:03 PM   #1
oldnavy638
Camshaft Position Sensor???
I have a 98 neon 2.0 SOHC. I scanned the car for codes and got the P0340 code which is the camshaft position sensor. I replaced the sensor today along with the wiring harness and i went and cleared the codes. Went to go start the car and it turns over but will not start still. I re-ran the codes and got the same P0340 code. Is there something else i can do? Any advice is greatly appreciated. Thank You
oldnavy638 is offline   Reply With Quote
Old 10-12-2007, 12:19 AM   #2
Nalayah
Re: Camshaft Position Sensor???
Are all the wires in good condition? How long did you crank it for?
Nalayah is offline   Reply With Quote
Old 10-12-2007, 08:43 AM   #3
oldnavy638
the wires were in good condition, im wondering if it something else also. Possibly not getting any spark. Ill have to look into it. The first time i went and started it a week ago one of the plugs popped right off so possibly its a ground issue as well?
Old 10-12-2007, 10:50 AM   #4
das2123
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
You say you replaced the harness also?
2003 Dodge SRT-4
das2123 is offline   Reply With Quote
Old 10-12-2007, 12:21 PM   #5
oldnavy638
yes i replaced the sensor and the harness
Old 10-12-2007, 01:11 PM   #6
das2123
The whole harness?
2003 Dodge SRT-4
Old 10-12-2007, 02:02 PM   #7
oldnavy638
The whole harness?
no just the plug but i traced the wires back pretty far and didnt see any bare wires
Old 10-13-2007, 09:34 AM   #8
jdl
I have heard of a faulty crank signal causing a cam sensor code. I'm not saying replace the crank sensor, check the signal circuit, with the engine cranking. That signal is dc pulse, if you have a dmm with a tach--dwell--duty cycle setting, anything like that will react to a dc pulse. You could turn the key on, turn the crank by hand, watch for a high--low signal on that circuit. It should switch between 5 volts and close to zero. Maybe you already checked all this, I didn't read it in your post.
I guess your saying the vehicle cranks good, but during cranking, there is no spark at the plugs or injector pulse?
jdl is offline   Reply With Quote
Old 10-13-2007, 10:13 AM   #9
oldnavy638
thats correct im not getting any spark
Old 10-13-2007, 10:22 AM   #10
jdl
On the cam sensor, the signal wire should be tan/yellow.
For the crank sensor, the signal wire should be gray/black, that should be a gray wire with black tracer. Your going to have to do the testing, I can't do that from here.
Old 10-13-2007, 12:34 PM   #11
oldnavy638
I appreciate all the info, i checked the wires and i am getting the correct signal. I finally figured out what it is. The timing belt slipped and now the timing is off. What a pain
Old 10-15-2007, 08:11 AM   #12
das2123
Yep, that can be a pain. Hopefully it didn't bend any valves. Make sure you check compression.
2003 Dodge SRT-4
Old 11-18-2008, 10:04 AM   #13
Moonzuk
Hello fellow enthusiasts,
I am facing some valve replacement here on 95'Highline.
And surely I'd like to start with some questions.
I did some walking-talking around through some local shops and collected some mixing ideas.
Someone said I'll have to replace ALL valves, some says NOT.
Some says that cylinders head MUST be removed and checked, some says it could be ok by visual examination.
Another thing is to remove the engine or do as Haynes manual described with that air tool and without removing the head.
In case if I decided to pull the engine out.
Are these engine stands from Harbor Freight will do any good or I'll have to be creative?
To disconnect transmission from engine - any good advise?
I may decide to replace rear main seal.
Yeah, sounds like load of do's.
Moonzuk is offline   Reply With Quote
Old 12-22-2008, 08:15 AM   #14
das2123
I personally would replace all the valves for peace of mind.
Head should be checked for straightness, but visual if not enough.
Any engine stand should do you good.
Pull the motor and tranny out together.
2003 Dodge SRT-4
