Go Back   Automotive Forums .com Car Chat > Chevrolet > Astro > M Bodies
Old 10-24-2008, 09:35 AM   #1
Steve47
A couple of questions
I'm thinking of having the rear axle replaced on the 1997 AWD. Is it easier and less costly to have the whole axle replaced or just have the internals of the differential replaced? Opinions?
Does anyone know if there is another connection for the speedometer in the dash cluster? Since I've been having a problem with the sensor at the transfer case in the past, my mechanic is now leaning towards the possibility there may be another connection at the cluster that may be the culprit.
Opinions?
If thewre is another connection, Can you put a name to it so I'd know what to look for or purchase?
Thanks opcorn:
Steve47 is offline   Reply With Quote
Old 10-25-2008, 11:36 PM   #2
Schrade
Re: A couple of questions
Opinions?
Thanks opcorn:
Rear axle? If the ring and pinion in the rear axle is all that's wrong, replace just them only.
Leaning mechanics bother me. ALOT.
Schrade is offline   Reply With Quote
Old 10-28-2008, 09:29 AM   #3
Steve47
I hear you about those leaning mechanics. I've used the same mechanic for a while now, a great mechanic is difficult to find.
Is the ring and pinion job a difficult job for a seasoned mechanic?
On a scale of 1 - 10 ,,, How expensive is it to do? Just looking out for my wallet.
Old 10-28-2008, 02:47 PM   #4
brcidd
brcidd's Avatar
I had the ring and pinion professionally replaced and "set-up" to the tune of $550 with a used 3rd member- about 7 yrs ago---I then blew that rear end out- about 6 yrs later, and opted for the whoile rear axle this time- cost me $150 from a salvage yard- and it was a whole lot easier to do- just had to tranfer some parking brake cables- and bleed the brakes- but without the right tools - you can't set the lash yourself- so I got a low mileage rear-end- that is already set-up- makes a whole lot more sense to me- and it was much cheaper. Of course when I had asked the professional about doing that 7 yrs ago- he said- no way-- but he can't make the big bucks that way- there is no "set up" labor...
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
brcidd is offline   Reply With Quote
Old 10-28-2008, 04:03 PM   #5
Steve47
I'm going for the whole rear end if I can find one. I had one put in a 99 Ford conversion van a couple of years ago. It cost me $300 for the rear ens and $175.00 for the mechanic to do it. Different mechanic than I use now but I'll go back to him.
This Asto is becoming the van from h*ll. I just went and got my kid on the side of the highway. The oil gauge was reading zero at idle, the oil is full to capacity, he said he thought it was going to overheat. I started it and applied a good amount of gas to the pedal, the oil pressure came up to 40, I dropped it in drive and took off, there was a bit of squealing from underneath up front, that went away, It didn't try to overheat, the fan came on and controlled the temp as it should, It was a bit sluggish going up hills on the way, when I cam to stop signs and such the check gauges light came on, but when I applied the gas it went off, I drove it about 8 miles to my mechanic and left it there, I told him maybe the oil filter is plugged, he said no, maybe the catalytic converter ,,, What do you guys think?
Old 10-29-2008, 10:46 AM   #6
Steve47
Spun rod bearing. The van is done! Not worth the repair.
Old 11-01-2008, 07:42 PM   #7
Blue Bowtie
Registered Offender
Blue Bowtie's Avatar
Pennzoil?
Old 11-02-2008, 10:50 AM   #8
Steve47
"Pennzoil?"
Now how could you possibly have known that?
Old 11-23-2008, 08:18 PM   #9
Steve47
You never answered the Pennzoil question. How'd you know. Is Pennzoil bad for engines?
I bought a Ford E250 for a replacement van but I'd still like to have the Astro done. Rebuilt engine and tranny for $2,601.00 with warranty.
Old 11-23-2008, 08:55 PM   #10
old_master
Advisor/Moderator
old_master's Avatar
Pennzoil and Fram, great stuff if you're not planning on driving the vehicle. The best place for both of them is on the parts store shelf. As soon as they leave the shelf, the problems start.
old_master is offline   Reply With Quote
Old 12-03-2008, 09:20 PM   #11
diggin
Fram is something I stopped buying a long time ago , dealer or Baldwin filters are all I ever buy now but I have not heard of the Pennzoil deal . Just for curiosity please do tell what the problem is with the oil.
diggin is offline   Reply With Quote
Old 12-06-2008, 10:54 PM   #12
Steve47
I'd like to know what's wrong with using Pennzoil as well. What can you tell us? That's a bold statement without an answer. Myself, I thought Pennzoil was supposed to be good. Now you've got me wondering.
Old 12-07-2008, 12:38 PM   #13
old_master
Advisor/Moderator
old_master's Avatar
I've had countless engines apart for repairs and more often then not, the ones that were sludged up the worst had a steady diet of Pennzoil. I can't give you a technical answer why, but with 30 some odd years experience in repairing them, I can offer my opinion and share the observations that I have made.
As far as oil filters, check this site: http://minimopar.knizefamily.net/oilfilters/index.html
Old 12-07-2008, 01:24 PM   #14
Blue Bowtie
Registered Offender
Pennzoil/Quaker State (same company) have historically (past evidence - They may have recently changed) used the lowest quality base stocks for blending consumer engine oils. That means that in order to meet API requirements, they have used fortifiers extensively. The polymers used to fortify oil typically fail early in their life cycle, burning and turning to sludge. A good oil filter will be able to trap some of that, but that leaves a lot less filter to trap other particulates.
Beyond the problem with sludge in the filter and the rest of the sludge in the engine, the rapid loss of polymers means the oil quickly reverts to its base form. The base oil that would once maintain viscosity at 300º with the aid of polymers becomes thinner than water, and provides very little lubricant film strength.
Engine oils are typically 75-85% base stock, with the remaining volume being comprised of additives. Because of this, base stock is critical to the performance of the final product. Poor quality base oils require more additive, and the additives frequently become contaminants as they are used. Beyond the tendency of the oil to fail, the volume of usable oil decreases as the filter and engine become clogged with sludge. Better oils, even mineral oils using better base stocks, do not suffer that tendency to anywhere near the same degree. Group IV synthetics do not suffer it at all.
If you use low-grade oil and change every 1,500-2,000 miles, you might just get by without serious engine wear and sludge. That's a gamble, but in the long run, you've saved nothing over using a superior lubricant changed one-third as often. You can take the big step to Group IV synthetics and use it confidently for up to 10,000 miles, more if you care to sample and analyze it.
Old 12-07-2008, 02:22 PM   #15
Blue Bowtie
Registered Offender
Old Master - I feel it necessary to warn you that if you continue to advise people to use good products, you may be held responsible for putting several good engine rebuilders out of business, and possibly eliminating an already strained segment of the economy. Do you really want that weight hanging over your head?
Please, keep our little secret. We'll keep driving while everyone else keeps rebuilding.
