Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Silverado
Old 02-27-2009, 05:48 PM   #1
ronjon2009
no brake lights
2000 chevy silverado. Tail and blinkers work. Bulbs are good. All the wiring looks clean. i'm trying to save the $90 diagnostic charge. I understand that there are a couple of switches to check, at the brake pedal and in the steering column. Is this true? Are there initial checks before I go tearing into the steering column?
Last edited by ronjon2009; 02-27-2009 at 07:29 PM. Reason: Needed to be more explicit
ronjon2009 is offline   Reply With Quote
Old 02-28-2009, 02:24 AM   #2
Yellow Snow
Send a message via MSN to Yellow Snow Send a message via Yahoo to Yellow Snow
Re: no break lights
I had a 96 grand am that all of a sudden lost it's break lights. It was a small plastic nut that held the switch the break pedal pushes to engage the lights. I think it cost like $2.00.
I'm retarded when it comes to repairing vehicles and I was able to figure it out just by looking around behind the break pedal. Hope this helps.
01 Silverado Z71 5.3
BFG All Terrains
Flowmaster Catback
Silverstar Ultra High/low
Sirius sat. radio
More to come.....
Yellow Snow is offline   Reply With Quote
Old 02-28-2009, 03:10 AM   #3
J-Ri
J-Ri's Avatar
Re: no break lights
The first thing to check any time anything doesn't work is fuses. If they're all good, check the brake switch. If that's good, you'll want to buy a repair manual for your truck so you have a wiring diagram to follow.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
J-Ri is offline   Reply With Quote
Old 02-28-2009, 06:50 PM   #4
sierra99
Re: no break lights
About 6 years ago my 99 silverado z71 had the same problem. I used a test probe and started to check everything. I found that my problem was a bad circuit board under the bed just behind the spare. There is one harness the feeds from the front (blue) and and then two connectors for each side harness, also one for the rear license plate lights. Take a look at that circuit board. Mine went bad at about 60k miles.
Take a test light and have somebody hit the brakes and make sure you can get your test light to come on testing the incoming wiring harness. Then plug in the harness back into the circuit board and then check the output.
Hope this helps
sierra99 is offline   Reply With Quote
Old 03-01-2009, 10:40 AM   #5
j cAT
Re: no break lights
on the rear end of your vehicle is just behind the rear bumper is an interface circuit......this unit gets corroded...I suspect this is your problem....the wires going to the rear of vehicle will all go into this block..
using a meter see that the BRAKE voltage is good with the pedal held down...going into this unit...then you will know for sure whats bad..
