Go Back   Automotive Forums .com Car Chat > Ford > Taurus | Taurus Wagon
Old 11-23-2008, 09:15 PM   #1
dmcogar
2000 taurus
Stalls at most every stop and won't stay running without foot on gas pedal. Replaced fuel filter already. Any ideas???? I'm a single mom and this is my daughters car. I hate to take it in without some idea of what might be wrong.
dmcogar is offline   Reply With Quote
Old 11-23-2008, 09:27 PM   #2
Scrapper
AF Premium User
Re: 2000 taurus
have you had fuel pump tested? if so it could be the tps snsor-throttle body sensor or maf sensor-mass-air-flow-sensor. is your check engine light on?
Scrapper is offline   Reply With Quote
Old 11-23-2008, 11:47 PM   #3
shorod
SHO No Mo
shorod's Avatar
Re: 2000 taurus
Does it run roughly or is it pretty smooth? You could have a vacuum leak, misfire on one or more cylinders, or an EGR valve that is not closing fully if the car runs roughly at low engine speed.
If the engine is still pretty smooth until you let all the way off the throttle, I'd suspect a bad Idle Air Control (IAC), aka Idle Speed Control, servo or a badly carboned up throttle body.
-Rod
Old 11-25-2008, 01:58 PM   #4
mattcruea
Re: 2000 taurus
This exact same problem happened to me a week or so ago on my 2000 Taurus Wagon. I guarantee you have a vacuum leak.
mattcruea is offline   Reply With Quote
Old 11-25-2008, 06:47 PM   #5
way2old
TOKEN HILLBILLY
way2old's Avatar
Re: 2000 taurus
I agree with Rod on the IAC. Try tapping on it with a screwdriver handle to see if it helps. A generic picture is below.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
way2old is offline   Reply With Quote
