Atf
The manual specifies to use dexron 3, dexron 4 is out, but dexron 3 is still available. It says 4 is compatible with transmission that use 3. I just wanted some opinions on this, because if I buy dexron 3 it comes to 3 bucks per quart while dexron 4 is about 6-7 bucks per quart. I read that dexron 4 has some additives that dexron 3 doesnt, but weather that is true or not I just want to know if my 99' Rodeo will like the 4 more and possibly help extend the transmission life and performance?
Re: Atf
Personally, I think the Dex 4 is a slightly thinner weight ATF.
I use Castrol Import ATF for GM transmissions of 2005 and earlier, i.e. Dex 3 I think it really depends on the total mileage of your tranny, and how often you've serviced it. I do partial fluid swaps every 12-15k miles and currently have 188k on mine, still shifts flawlessly.
1997 3.2L V6 Rodeo 32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack On it's way to 185k strong ![]() 2004 3.4L Tacoma TRD off-road 4x4 Double cab 32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Re: Atf
Re: Atf
Then I'd use a regular ATF Dex 3, do not be putting anything synthetic in there.
AND, do NOT do a transmission flush on that tranny, it will most likely destroy it.
Re: Atf
Is O'Reilly a good brand? I've never heard of them before.
Re: Atf
Don't know.
I've only ever used Castrol Import ATF found at Autozone or Advanced Auto, think it was somewhere around $3.70/qt or so.
