Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 11-08-2008, 11:14 AM
slalsma slalsma is offline
99 5sfe will not start no fuel at engine
My daughter's car died and will not start. Tried to diagnose thr problem using this forum and Alldatadiy.com. Getting no fuel pressure at the fuel filter applied battery voltage to the fuel pump and the fuel pump runs. Checked the ECU B+ voltage was at 12V. Checked the fuel pump circuit by grounding the FC terminal at he ECU and fuel pump runs. Replaced ECU with one from the salvage yard no changes. If anyone has any experience with this sort of problem I would appreciate your advice.
Old 11-08-2008, 01:34 PM
somick's Avatar
somick somick is offline
Re: 99 5sfe will not start no fuel at engine
If your pump runs and you still not getting fuel presure it points out to a bad fuel pump.
Did you try fuel gauge when you powered your pump directly?
Did you try www.camrystuff.com? They suppose to have the diagnostics procedures for fuel pump as well as for ECU.
Good luck,
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
Old 11-08-2008, 05:38 PM
Don't have a banjo fitting needed to attach a gauge at the fuel pump but I did squeeze the line off and felt the fuel run through the line when the fuel pump was running. Thanks for the link I will check it out.
Old 11-09-2008, 12:53 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
You're not getting fuel at the filter but you're feeling fuel run through a line - where?
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 11-09-2008, 09:15 AM
I feel fuel run between the filter and the engine only when the fuel pump circuit is grounded at the ECU. Failed to check it when the pump was wired direct.
Old 11-10-2008, 03:42 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
This is only a stab but, if equipped I'm wondering if the engine immobilizer system may be engaged. I believe it cuts power to the fuel pump and am guessing by not supplying the ground you're missing from the ECM. You can read up on it in the factory maintenence manual found in the "Factory Service Manual" thread at the top of the forum. Look under "diagnostics" on pages 919-937.
Have you checked for fault codes?
Old 11-11-2008, 07:55 AM
I've really made a mess of things now.I was trying to test circuits and left the ignition switch on and now the battery is dead. I only have a cheap charger which will take a while to recharge the battery. In the mean time I will check out the anti theft circuit diagram in the service manual and the fault codes when I gat the battery recharged.
