Go Back   Automotive Forums Car Chat > Chevrolet > Blazer > Problem Diagnosis
Old 09-18-2008, 05:46 AM
92sonomasl 92sonomasl is offline
92 S15 missing - diagnosis?
I have a 92 Sonoma with a 2.5 iron duke/5 spd. manual. Ever since it was new it would stumble when it was cold under acceleration (for the first 1/2 mile or so). The new problem is that this stumbling will occur off & on (slowly getting worse), but I have noticed some patterns. I can always get it it stumble after turning a corner quickly (at any throttle setting), or under hard acceleration most times. I have replaced the O2 sensor, fuel filter, dist cap & rotor (2 x) and plugs (with correct gap). I haven't pulled any codes, but from other threads I'm thinking it may be the coil or associated wiring. As the problem is intermittent, I suspect a ground/electrical issue rather than fuel problem. Anyone out there with similar issues/solutions?
Old 09-21-2008, 09:35 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 92 S15 missing - diagnosis?
Has it got any codes?
MT
Old 10-29-2008, 03:36 AM
Found the problem - had codes for egr valve and coolant temp sending unit. Replaced the egr valve first and it ran fine for 10 minutes or so and then started poppin' and fartin' again. I took the egr off and cleaned it, then installed a new coolant temp sensor and it runs fine now. I suspect that it was the coolant sensor all along, slowly failing until finally it wouldn't run hardly at all. I've replaced the following:
fuel filter
cap/rotor/plugs
plug & coil wires
egr valve
coolant sensor
Thanks for the help!
Old 10-29-2008, 09:14 AM
MT-2500's Avatar
AF - Advisor
fuel filter
cap/rotor/plugs
plug & coil wires
egr valve
coolant sensor
You are welcome and.
Thanks for letting us know how it went.
On the EGR valve watch it real close they are bad on getting carbon balls under the plunger.
Good Luck
MT
Old 10-29-2008, 09:47 AM
Schrade Schrade is offline
Good motor / tranny combo. Had it in my '81 CJ-7. Bored, ported shaved head and intake, headers - yup - headers on a 4 holer!!!. Ran like a top. Even put the motor in BY HAND uh huh!
