Go Back   Automotive Forums .com Car Chat > Saturn > SC/SL/SW
Old 10-30-2008, 08:36 PM   #1
FixMySaturn
Automatice saturn wont shift right
My 2001 saturn sl1 or 2 series wont shift right....it jumps when hitting first second and third gear and also sometimes when I brake ...anyone who can tell me whats wrong and an estimate of how much it may cost to fix ...someone said the rpm needs to be adjusted ?...
FixMySaturn is offline   Reply With Quote
Old 10-31-2008, 02:29 AM   #2
RC1488
Re: Automatice saturn wont shift right
Is it a DOHC or SOHC engine? DOHC are Sl2 SOHC are Sl1.
Replace your ECTS. Only some of 2001's came with the brass new style one. I suggest dealer however they upped the price to 19.50. AZ or AA has it for cheaper, but get teflon tape so that it doesnt leak fluid
replace this and drive around for a little bit. See if it helps.
Does it slam into gear? Slam into reverse?
Present: '02 Sl1 Man '01 SC1 Man '97 Sl2 Auto '96 SL2 Auto '95 SC2 Man
Past: '99 Sl2 Auto '97 Sl2 Man '98 SL2 Man '95 Sl2 Man '95 Sl2 Man '94 Sl2 man
RC1488 is offline   Reply With Quote
Old 11-07-2008, 06:31 AM   #3
reino134
Send a message via AIM to reino134 Send a message via MSN to reino134 Send a message via Yahoo to reino134
my 01 sl2 w/ 134,000 did the same thing. First I changed the 4 motor and tranny mounts ( which were totally shot ) and that helped it some. Then I replaced the tranny valve body, which I purchased off of ebay rebuilt for about $200 delivered (a local shop wanted $900 to do this) the job is very easy to do and took about 45 min. My sl2 runs and shifts like a brand new car now and Im gettitng around 34 - 36 mpg. Well worth the repair cost!
reino134 is offline   Reply With Quote
Old 11-19-2008, 03:11 PM   #4
FixMySaturn
Yea it makes a big bang so Im guessing thats basically slamming
Old 11-20-2008, 12:06 AM   #5
RC1488
Yupp. Reverse slam syndrom. Do wolmans cure and see if that helps. If not then a new valve body may be in order.
Old 12-03-2008, 08:45 PM   #6
Operator4100
Hey all, my Daughter's saturn is doing the transmission slaming, any sure fire ways to cure it
Operator4100 is offline   Reply With Quote
Old 12-04-2008, 12:08 PM   #7
RC1488
Wolfmans reverse slam remedy.
New in put shaft nut.
New valve body.
Those are the three steps to fixing the reverse slam syndrome. Depending on how bad it is, its sometimes cured with the remedy
