Old 09-12-2006, 03:23 PM   #1
matt narron
2000 rodeo 3500 rpms at 75 mph..what do i need to do
my 2000 rodeo 2.2. 5 speed has it share of problems...
it is reving up to 3500 rpm's at 75 mph some people say i need a clutch some say it's the timing..
any help would be greatly apprciated....
Matt Narron
matt narron is offline   Reply With Quote
Old 09-12-2006, 04:53 PM   #2
Ramblin Fever
Re: 2000 rodeo 3500 rpms at 75 mph..what do i need to do
Well, if it was a 3.2L V6 with the automatic that would be normal.
Mine rides at 3200 rpm at 75mph all the time - has since bought new.
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Ramblin Fever is offline   Reply With Quote
Old 09-12-2006, 04:58 PM   #3
Ramblin Fever
Wanted to add though, I believe the timing belt on the 2.2L 4-cylinder is due EVERY 40k or 60k, can't remember which it is for sure, look at your owners manual, but do NOT go over the recommended interval for the timing belt. These belts, if they break, will due SEVERE damage to the engine.
1997 3.2L V6 Rodeo
Old 09-13-2006, 07:51 AM   #4
Mirock
I would put my many on the clutch.
Is it slipping going up hill? How many miles on the truck?
Mine 99' V6 DOHC automatic,rides at some 2700rpm at 75 mph.
99' rodeo 4X4 LS
99' mazda 626 wife's toy
Mirock is offline   Reply With Quote
Old 09-13-2006, 08:33 AM   #5
redbug
Isn't 3500 RPM about normal for an engine that small pushing a large vehicle 75mph? Probably any slower and you would fry it up....
Has that rpm changed? If so, if it is a manual clutch it's probably slipping... High gear is the greatest load on a clutch....
I had a 1985 Trooper (first year in US) 1.9 litre, it was at 4000 rpm going 65 mph.... Engine was so small with a large water jacket... In the winter at idle the temperature guage would go down... Had to wear gloves and a hat because it was so cold in the large cabin...
redbug is offline   Reply With Quote
Old 09-13-2006, 08:47 AM   #6
matt narron
not sure if it is slipping ...it slows down alot going up hill though..\
it's got 90,000 miles ...i bought it with 57,000
Old 09-13-2006, 08:52 AM   #7
matt narron
i think it was at 3000 rpm going 70mph ....it has incresed some...3200 rpm going 70mph
Old 09-13-2006, 10:42 AM   #8
directory
directory's Avatar
aren't there a lot of different factors that may push the rpm's up? outside temp, engine temp, tire size, in vehicle load, etc...
do you have any trans or cel codes being thrown at you?
99 passport 3.2L v6 DOHC auto-trans 4x4 modified IFS 10 bolt front/ dana 44 4.10 rear
SKYWARN
we be clubbin'
--B
directory is offline   Reply With Quote
Old 09-13-2006, 12:32 PM   #9
matt narron
this is true...there could be alot of diffrent factors..
the check engine light comes and goes...seems to go off when i get under 1/2 tank of gas...
quote=directory]aren't there a lot of different factors that may push the rpm's up? outside temp, engine temp, tire size, in vehicle load, etc...
do you have any trans or cel codes being thrown at you?[/quote]
Old 09-13-2006, 02:15 PM   #10
redbug
Is this an automatic? If so, it surely is downshifting from high gear when you go up a hill, causing the engine to speed up. (faster engine speed, more horsepower) And yes, tire pressure, vehicle load, etc may make the transmission downshift sooner. Tire size, yes, but have you changed them lately? Normal wear on your tread will be negligble for your measurements.
If you are on a level with an automatic it should put you in high gear and your rpms should not fluctuate greatly. Most new transmissions actually "Lock In" on high gear to avoid any slippage from the fluid clutch... Not sure on the Rodeo, but I would suspect that the 2000 has this....
If it is a stick, then if you are in high gear there should be no fluctuation between your RPM/MPH measurements... A hypothetical example: a measurement for a vehicle at 3000 rpm shows 70 mph whether going up a hill or not. (unless your clutch is slipping)
Old 09-13-2006, 05:37 PM   #11
Ramblin Fever
I deleted previous post - my error, was relating to an automatic, forgot that you mentioned having owned a stick shift.
Yes, your clutch is slipping - need a new clutch from the sounds of it.
1997 3.2L V6 Rodeo
Old 09-15-2006, 09:09 AM   #12
matt narron
Thumbs up Re: 2000 rodeo 3500 rpms at 75 mph..what do i need to do
thanks for your help....
hopefully i will be able to get a clutch soon...
Old 09-25-2008, 01:24 AM   #13
vamp999
Re: 1900 rodeo 8500 rpms at 15mph..what do i need to do
I tell you what you can do, you can get you a gallon a gas pour on the engine. Then get you a match and burn it.
vamp999 is offline   Reply With Quote
Old 09-25-2008, 09:13 AM   #14
matt narron
i guess i could have done that ..thought about pushing it in the Neuse River(Johnston Co. N.C). But my wife would not let me ....ended up trading for a little compact car ......every thing is better ..no clutch issues..and no more rodeo ...which i did enjoy when it ran ...
Old 10-01-2008, 06:33 PM   #15
okmech1
"the check engine light comes and goes...seems to go off when i get under 1/2 tank of gas..."
Matt,
This would be due to your fuel sending unit. Not too hard of a fix - requires you to drop the fuel tank to remove the pump unit and replace the sending unit on that assembly.
2001 Honda Passport 3.2L V6, all stock - 90K
2009 Toyota Matrix - 10K
okmech1 is offline   Reply With Quote
