Can't get '94 626 to pass emissions.
I'm located in St. Charles, MO & I can't get my '94 626 to pass emissions. Here is a list of problems & repairs for the last year:
August 2005 (Car was bought 2 months prior & passed emissions.) [Problem] -Fiancee is driving car on expressway & it just dies on her. [Repair] -Neighbor tells me it is timing belt. I tear the engine apart to get to belt. After determining the belt is fine, neighbor then tells me it is the distributor. August 2005 - May 2006 -The car sits immobile. May 2006 [Repair] -I throw a used distributor on (luckily in the correct timming position) & the can runs but rough. I adjust the idle speed screw so that car doesn't die when idling. July 2006 - October 2006 -Car sits, seldomly driven. (Late) October 2006 [Problem] Car is taken through emissions testing & fails (3 days ago). Readings are as follows: -Hydrocarbons/ Standard: 0.8000 Grams Reading: 2.3388 Grams -Carbon Monoxide/ Standard: 15.000 Grams Reading: 6.7961 Grams(PASS) -Oxides of Nitrogen/ Standard: 2.000 Grams Reading: 9.1611 Grams <br> [Repairs] -I replaced the spark plugs, air filter, & PCV Valve. I changed the oil. I added CRC-"Guaranteed To Pass Emissions Test Formula" to a full tank of gas & followed directions EXACTLY. I refilled the gas tank with Premium gas & added a bottle of "HEET" as recommended by person at Advance Auto Parts. I then ran the car through emissions again (only hours ago) and it failed AGAIN. Here are the results: -Hydrocarbons/ Reading: 2.4431 Grams -Carbon Monoxide/ Reading: 6.7961 Grams -Oxides of Nitrogen/ Reading: 7.9973 Grams Any suggestions before I have to take the car to a mechanic for costly repairs? A buddy of mine said I could try to change the Oxygen Sensor. |
![]() Join Date: Dec 2006
Re: Can't get '94 626 to pass emissions.
Did you get the car to pass and if so what did you have to replace to get it to pass?
GTP sucks, used it on my Taurus and it failed miserably. I used methal hydrate, my car passed with flying colours. I filled my tank with regular added the methal hydrate, drove it till it was half and refilled. Try it and let me know what happens
![]() Join Date: Sep 2004
Please check the date of the last post in the thread and do not respond if that date is longer than 3 months from the current date.
From AF's Community Guidelines: POSTING IN CLOSED OR OUTDATED THREADS: If a thread has been closed, there is probably a logical reason for it. If you feel that the reason(s) for closure of the original thread are unjustified or wish further clarification feel free to contact any member of the moderating team. However, do not start a new thread about another closed thread. Please avoid posting or voting in outdated threads. It merely clutters up the message board and makes it more difficult for fellow members to sort through the vast amount of information contained on the boards. If you have new and important information to add regarding a past discussion, feel free to start a new thread and if need be, add a link to the original thread. The link to these guidelines can be found here:http://www.automotiveforums.com/vbul...uidelines.html Closed.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people. ![]() If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno |
