Go Back   Automotive Forums Car Chat > Buick > Skylark
Old 09-19-2008, 11:25 PM
marblemike marblemike is offline
95 buick skylark headlights dont work
Hi
all my running lights work but head lights wont come on unless you pull the dimmer arm back and hold it, turn signals, flashers turn all work.
any info would be greatly appreciated.
Thanks mike
Old 09-20-2008, 01:54 AM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: 95 buick skylark headlights dont work
When you pull it back is it turning on the high beams?
I assume you already checked the bulbs and checked to see if there is power to them?
Old 09-20-2008, 11:06 PM
Hi
Problem was in the headlight switch.
went to salvage yard and got one i thought would work.
parts house wanted 135.00 dollars and had to order it.
it turned into a couple hour job but i took old one off tore it apart.
the other one i got at salvage wouldnt work a little different so used parts from the salvaged part to rebuild old one and it works fine.
Thanks
Mike
