Go Back   Automotive Forums .com Car Chat > Chrysler > Lebaron
Old 09-03-2008, 04:14 PM   #1
yellowv
91' vert AC problem
Hey guys my Dad just bought a 91' LeBaron convertible. The AC works, but as soon as you accelerate it shuts off the dash vents and blows from the floor vents. Slow down and stop and it blows from the dash again. We checked all the vacuum lines and everything seems to be fine with no leaks and hooked up where it belongs. We also replaced the check valve on the vacuum line on the booster. No luck. Any suggestions before we go ripping the dash out? Thanks.
yellowv is offline   Reply With Quote
Old 09-04-2008, 04:11 PM   #2
KManiac
KManiac's Avatar
Re: 91' vert AC problem
I once had a 1991 Dodge Shadow coupe that did the same thing brand new. There is no need to rip the dash apart because the problem is not there. The check valve to the power brake booster has no effect on the vent system so replacement of that valve was a useless effort.
What is happening is that there is either no check valve or a disfunctional check valve between the vacuum sourse to your vent system and the vent system itself. Everytime you accelerate and drop manifold vacuum, the vents redirect on that loss of vacuum.
Trace the vacuum lines under the hood between the vent system and the sourse of vacuum. If no check valve exists, buy one and install. If you find one there, replace it.
Let us know what you find and what you do.
"This car may be old, but it will still climb Kirker Pass at 110!"
1962 Chrysler 300 2-door hardtop/1964 Chrysler 300-K convertible/1964 Chrysler Newport 4-door sedan/1964 Chrysler 300-K hardtop with Firepower 390/2x1964 Chrysler 300-K hardtop/1964 Chrysler 300 convertible/1964 Chrysler "Silver 300-K" with factory 4-speed/1964 Chrysler New Yorker Salon/1980 Dodge D-50 Sport/1986 Lincoln Continental/1989 Honda Accord DX/1989 Lincoln Mark VII BB/1991 Dodge Shadow ES convertible
KManiac is offline   Reply With Quote
Old 09-07-2008, 09:19 PM   #3
madmanmapper
madmanmapper's Avatar
Yes KManiac is right.
However, ripping out the dash is very simple on most EEKs including the 91 LeBaron. There's 4 or 5 3/8"/10mm bolts on the top, right where the dash meets the windshield, then one 1/2"/13mm bolt/nut on each side by the doors, accessible from below the dash, and then there's 2 nuts holding the steering column up, and that's about it. The hard part is getting the dash to move more than 12 inches or so back, all the wires prevent it from moving very much.
madmanmapper is offline   Reply With Quote
