blinkers/flashers...have a mind of their own
I bought a 2004 Alero about 4 months ago. Overall, it is in pretty good condition. However, like any used car, it has it's flaws. First of all, the blinkers, flashers don't work all of the time. The flashers will not come on unless I fiddle with the button and even then they will only stay one for a second while the button is in a certain spot. The blinkers will work sometimes, but when they don't I can fiddle with the flasher button to get them to work. I did not have this problem when I bought the car. The blinkers were working fine and the flashers were definitely working. However, right after I bought my car, I had to take it in to have the cruise control switch replaced because the cruise control wasn't working. Shortly afterward is when I started noticing problems with the blinkers and just happened to push the flasher button one night to discover that it wasn't working. Could something have happened to the car at the shop to make the flashers and blinkers quit working properly?
Re: blinkers/flashers...have a mind of their own
This is a very common Alero problem. there was a recall on 99-02 Aleros for this same issue. The solution was to replace the hazard light switch (I assume that's what you mean by 'flashers'). It's not a hard or long job, and I think the switch is only about $60. Any mechanic could do it, probably in less than 15 minutes.
You will also at some point get an intermittent noise like the blinkers are on but they are not. This would be the turn signal switch grounding the white wire from the hazard switch. Replacing the turn signal switch, which is also common, will usual fix it.
#4 | ||
![]() Join Date: Jan 2005
Click here On the hazard switch fix GM sent notices out to at least '99-'03 Alero owners that the hazard switch would be repaired and/or replaced for free. Best to contact GM Customer Service and see if it qualifies. All they need is the VIN. It was a recall and on record at NHTSA.
'08 Pontiac Grand Prix GXP (Dark Slate Metallic) - LS4 5.3L V8 '02 Oldsmobile Alero GL2 - LA1 3400 V6 '99 Buick Regal LS - L36 Series II 3800 V6 '03 Honda CR250R MX - 2 Stroke 250cc '97 Pontiac Grand Prix GTP - L67 Series II 3800 V6 Supercharged (Sold) Timeslip 08/12/06 AF Community Guidelines Last edited by BNaylor; 09-20-2008 at 09:00 AM. |
