Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 08-26-2008, 11:52 AM
Machaon Machaon is offline
My Ranger 3.5L would stall, idle rough. Had P1131 OBD code. Cleaned MAF. Works GREAT!
My "Check Engine" light had been on for about two years, on my 4cyl 2000 Ford Ranger. It ran a little rough, but it had always run rough. For the past six months, or so, it got worse and started to stall out upon stopping.
I finally broke down and purchased an OBD diagnostic tool, checked the codes and found out that I had a P1131 and P1132, which indicated that the Oxygen Sensors were not happy. I looked these codes up on the Internet and found the suggestion to first clean the MAF (Mass Air Flow).
I opened the hood and found out that the MAF has special Torx "Security" screws. I couldn't find the Torx bits locally, so I purchased a set through the Internet. I also purchased a can of MAF cleaner.
I unplugged the electrical plug to the MAF and removed the two Torx "Security" screws and then looked at the two wires that I was supposed to clean, and saw that they were completely clean. Not a spot of dirt or anything on them. I was not happy. I was going to have to bring my Ranger in for servicing, where it would cost me a bundle, probably require several trips, long waits and frustration as they experimented with my truck and my wallet.
I sprayed the very clean wires anyway. What did I have to lose. I took it for a test drive. It seemed to operate better, so I sprayed the "clean" wires again a few days later.
Well..... guess what! The truck is riding like new! It is not stalling! The OBD codes are gone! My Ford Ranger and I are back on speaking terms!
I plan to clean the MAF wires periodically.
