Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer > Performance
Performance Discuss Engine, Suspension, Drivetrain, and all other performance modifications here.
Old 08-17-2008, 03:10 AM   #1
jakeyf08
exhaust question
I installed a glasspack cherry bomb muffler on my 96 blazer, but i would like my exhaust to be a little louder. If i remove the cat will this help? and if i remove the cat will this make my truck run bad?
jakeyf08 is offline   Reply With Quote
Old 08-17-2008, 11:55 PM   #2
ZL1power69
GM S-Series Mod
ZL1power69's Avatar
Re: exhaust question
If you remove the cat, your truck will run like crap, your ses light will be on, and your truck will now be illegal to use on public roads. Glasspacks are pretty loud already but if you want it louder, install a high flow cat. That way you stay legal and the truck may perform better. Also, glasspack break in and get louder as time goes on untill they completely burn out and become a hollow pipe.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
ZL1power69 is offline   Reply With Quote
Old 08-18-2008, 05:32 PM   #3
jakeyf08
do you recommend any specific high flow cat? and how much would a cat back system cost...around 500 600?
Old 08-18-2008, 05:54 PM   #4
spytearbite
Banned
You would have to show me how a bunch of metal is bounced off a few wet molecules that the car will run like junk? More unspent on the reversion is going to ruin the tune? opcorn:
You cannot create or destroy matter. So, it really does not matter if that is a solid, liquid or gas is all the same joke. Really, think about it.
You are just letting air out a less restricted area. Say you have the door half open and there is your breeze into the house. Say you open the door wide open and now all you really did was remove the door (or cat honeycomb metal air passes through); that convert 02 into not so bad, solid, liquid, gas out the pipe is still millions of gallons out of the ground we are now breathing say. A few more unspent molecules are not going to matter you removing the chemical reactor, (cat).
So, technically, you remove the cat, you just let the engine breath sooner is because; the engine is a pre-rated HP, meaning, bore/stroke/cam/EFI = Fuel trim my ECM.
All you accomplished wass move air quicker and brought out the same HP sooner. Or, torque being the reciprocate you being pushed in the seat a little quicker on the throttle apply.
spytearbite is offline   Reply With Quote
Old 08-18-2008, 10:05 PM   #5
ZL1power69
GM S-Series Mod
ZL1power69's Avatar
Either a Catco or Magnaflow. A universal version should be about $50-$70. As for a catback, a custom one with the muffler of your choice shouldn't be more than $250. Dynomax makes a bolt on kit for 4dr's for $160 and Gibson makes one for $350.
Low 11 sec sleeper
My Cardomain
Old 08-25-2008, 03:16 AM   #6
jakeyf08
i want to purchase a high flow magnaflow cat but i am unsure which one to buy...any suggestions?
Old 08-25-2008, 01:22 PM   #7
ZL1power69
GM S-Series Mod
ZL1power69's Avatar
Stock size for the cat is 2.5in.
Low 11 sec sleeper
My Cardomain
Old 08-26-2008, 07:42 PM   #8
jakeyf08
I ordered the magnaflow direct fit cat. hopefully it performs like i want it to!
