Go Back   Automotive Forums .com Car Chat > Volkswagen > Beetle - New/New Beetle Convertible
Old 07-21-2008, 09:38 PM   #1
autotechzf
Question Please Help cam sensor code
i am working in a 2000 new beetle with a 2.0 the car started missing alot and had misfire codes for all cylinders and a cam sensor code after many tests i replaced the cam sensor it did not change a thing i also replaced the coil no matter what i do it resets the cam sensor code if anyone has any ideas i would greatly appreciate it
autotechzf is offline   Reply With Quote
Old 07-22-2008, 07:24 AM   #2
hako
Re: Please Help cam sensor code
My Haynes Manual (number 3798) indicates that the engine speed sensor and the the crankshaft position sensor plus the voltage supply to the camshaft position sensor all need checking .....the procedure is outlined in this manual.
I'd check all these things. Good Luck.
hako is offline   Reply With Quote
Old 07-30-2008, 10:34 PM   #3
veedubmechanic
VDUBMAN
veedubmechanic's Avatar
if the timing belt was just done check the cam gear reluctor ring on the cam gear for being bent or broken.
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
veedubmechanic is offline   Reply With Quote
Old 08-24-2008, 11:55 PM   #4
JackDaniels386
sounds like the timing is off just enough to set the fault. sometimes when you do a timing belt on these cars and you have the timing off just a tooth it will set a code, but still run fine. if its off a lot, itll cause it to run rough and set the code. if its off even worse, it could cause valve damage. but it sounds like yours might have just jumped time. set it on TDC and look at your mark at the crank and the mark at the cam gear.
JackDaniels386 is offline   Reply With Quote
