bad, leaky, fuel injector
my check engine light came on, dealer states the computer said there is a leaky fuel injector. any one had any experience with this? i have a '94 SE, it seems to be running fine with slightly poor gas mileage. there are 176,000 miles on the truck. can i fix it, or is it too involved for my driveway?
Re: bad, leaky, fuel injector
No expert, but if your getting a Running Rich code, signs for a internally leaking injector would be hard cold start (taking longer than 2+ seconds), carbon soot at tail pipe, <10% reduction in fuel mileage, slightly rough at idle but no noticable problems at WideOpen, and the loss of fuel pressure after the engine is turned off.
A scan tool could verify that engine sensors (MAP, ECT, MAF, EGR, etc)are working properly and that the main computer (PCM) is trying to reduce the fuel delivered. As most systems can only increase or decrease deliver by ~15%, it will give some identication that it can't control the situation. There's no code (OBD I or II) for a leaky injector; most newer vehicles (OBD II) would get a P0172 (System Rich) code and eventually if ignored a P0420 (catalyst effectiveness low). From working on fuel inj'ed vehicles for 10 years now, I can say that as regular maintenance, injector cleaner should be added to a tank of fuel every other oil change or so, but its unlikely that cleaner will help in your situation, deposit are either causing one injector not to flow enough so vechile is increasing output of all injector (weakest link) to compensate/ protect for a more dangerously lean condition. Averaging around $100 for one injector for local parts store, I suggest repalcing all as a set (assuming that the current set is original equipment). Ouch! But if you could test the fuel pressure (see earlier) but with the injectors attached to the fuel rail but out of the engine, you could find the culprit singularly. |
![]() Join Date: May 2004
So if the system were too lean (PO171 and PO174) would that mean that the injectors aren't allowing enough gas through? Therefore, needing cleaning, or at worst case... new injectors?
JOAT's: There IS an error code for a leaky injector, it's code #45.
You can pull spark plugs one at a time and see which one is wet with fuel, then replace THAT injector, or pull all the injectors off, turn on the key and see which one drips when pressurized. This stuff is all available in the 1994 factory service manual, available from phatG20.net for download for free...
88 XE V6 4x4, 33x13.50 Swampers, 6" lift, winch, etc etc etc Admin of NPORA, Moderator for NPM, AllNissans.com and NissanHelp.com forums
