tire wobbles
I have a 1987 Cherokee with the 4.0 inline 6 my front drivers side tire when im driving wobbles I check the ball joints and baring they look good any one no what it is thanks for reading
Re: tire wobbles
sounds like a seperated tire..if every thing is tight. dose it pull to one side? if so it does have a belt seperated.you can try to switch right to left on you tires.another thing a bent rim..
Re: tire wobbles
i tryed swaping tires when you are driving you can look out the window and see the tire wobble
Re: tire wobbles
TIre wobble, do you have any vibration in the floor or steering wheel. Even though a tire is round, it is not perfect, ie the reason for balancing. There will be a minor imperfections in the tire to make it look like it is "wobbling". IF you jck the tire up, and place a bar under the tire, lift up, and there is NO movement, and NO cornoer to corner play, then you are fine. If you jackit up and the tire just "flops" then you could have other issues, like abearing failure.
