Hi,
Can anyone tell me how to adjust the rear brake shoes on a 2001 Protege 1.6? I took the drums off but I don't see any adjustment wheel. Thanks for your help! |
Re: 2001 Protege 1.6L
My 02 manual doesn't give a procedure, it does show the adjuster. I found this WikiAnswers that may help.
Clifton "How Self adjusting brake system works in mazda protege 2000. I couldn't found any adjuster screw with star wheel as many of the documents suggest. I have mazda protege manual and i can give a snapshot? In: Asian Cars [Edit] On 2000 mazda protege's the rear drum brake shoes use self-adjusters, they (sometimes) self-adjust, it looks like two levers facing each other and when you push the brake shoes away from each other the self adjusters move out more, adjust these until there is about 1 turn of drag on your brake rotor with the drum on, of course. If the handbrake is still lower than desired there is a 10mm nut (use a deep socket) on the drivers side of the handle inside the rubber flap, turn this to adjust brake lever height." |
