Spark Plugs
I have a 2006 chevy cobalt & it has been sputtering & i looked under the hood to change the spark plugs but i didnt see any. Can any one please tell me where under the hood is the spark plugs for this car? Any advise would be apreachiated
Re: Spark Plugs
There is a cover in the center of the engine that runs from the front to the rear (more than likely says Ecotec on it, and I think I remember some lines on it), it has an electrical connector on the rear. Unplug the connector and remove that cover and the spark plugs are down below.
Since I helped you out, maybe you could help me out? I am thinking about buying a Cobalt, if you could respond to my post titled "Buying a Cobalt?" I would appreciate it, even if all you can answer is how you like it. http://www.automotiveforums.com/vbul...d.php?t=912666
'04 Cavalier coupe M/T 2.2 Ecotec Supercharged 14 PSI boost, charge air cooler, 42# injectors Tuned with HP Tuners Poly engine/trans/control arm bushings Self built and self programmed progressive methanol injection system Last edited by J-Ri; 07-16-2008 at 05:11 PM. |
