91 ram 250 2wd front discs
can anyone tell me if the front rotors are made in two pieces
does the rotor and hub assembly seperate? do i have remove the studs to seperate rotor from hub? |
Re: 91 ram 250 2wd front discs
It is one piece,remove the dust cap and a cotter key should be showing holding the nut on.Remove the cotter key and remove the nut and it will come out.Put the nut on,this is a way removing the back bearing with out harming the seal.Pull on the rotor about 2 times and the seal will come off first including the bearing.
these are not the same as older style gas engine truck rotors(its a diesel)
they look more like fwd rotors thanks for the reply |
