| B-Series/Bravo/Bounty/Drifter Bravo is the Australian vesion, Bounty the New Zealand version and Drifter the South African version. |
B2000 won't idle after warm up
My 1986 B2000 won't idle at all after warm up. When it starts cold, the choke is set and it warms up fine. As soon as it is warm and the throttle goes back to normal, it dies almost like turning off the key. It drives fine, but when you come to a stop the motor dies. I am looking at the EGR valve now but haven't come to any conclusions. Help.
Re: B2000 won't idle after warm up
I have about the same issue.
To cope, I dialed the idle up to about 1000. She idles then. My problems are - leaks at exhaust, need fuel pressure regulator for the new Weber Carb, and needs a tuneup. I do not know if one of these is the culprit. My suggestions - If you still have the stock carb, look for a vacuum leak. Exhaust leak? Clogged catylitic converters? |
This idle problem started very abruptly. It was running fine. When I came up to a stop, the motor died...been the same since. I have ruled out the EGR valve. It is closing properly. In fact, I took it off and plugged the intake port...still died after warm up. I'm going to check the idle switch next. Maybe it's open and not telling the control module that the throttle is at idle position.
bstrom1953 |
hi
just wondering if anyone solved this problem i have the same thing put the b2200 into a former b2600 then the problem started thanks lou |
bypassed the problem by removing the plunger and spring from the slow idle solenoid
let me know if anyone wants the details lou |
sounds like u need 2 rebuild the carb the top gasket is notorius for coming lose and creating a leak u may try tightning all the screws but chances are it will still need 2 b rebuilt good luck
