Old 06-16-2008, 10:33 PM   #1
jason235744
Question no a/c no shift check engine light on
94 z34 auto, check engine light comes on , trans only has 2,3 and reverse, i get low volt code for tps, a.c. does not work , it tends to do this more when car is cold. may only do this for a few miles , turn off car start back and ever thing is normal , i am sure trans , a/c and tps all get power from same wire from computer, just alot of things to rule out i just wonder if anyone else has had this problem.
jason235744 is offline   Reply With Quote
Old 06-16-2008, 10:45 PM   #2
jeffcoslacker
Lactose the Intolerant
jeffcoslacker's Avatar
Re: no a/c no shift check engine light on
I don't know but I think I'd start with checking the ECM ground(s)
...empty gun rack.
Old 06-17-2008, 01:35 AM   #3
randy78
Send a message via Yahoo to randy78 Send a message via Skype™ to randy78
hi there yes check ground wires at bellhousing bolt in the front
if they are fine try removing the a/c fuse and see how it does then
the compressor clutch coil may be shorted
had this same issue on the 98 achieva and had the same symptoms and troubles as well
have also had some cars with runnign and idling issues missing stalling and it was bad broken wires for the grounds at the bellhousing bolt
so...
I also am user fastr68 here- Randy
-'54 F100 302 C-6 -'57 F100 -'57 Bel Air HT 307 4spd '57 210 HT 4dr 265 3spd -'68 corvair monza convertible w/ PG -'79 C-20 -'80 K-20 -'82 K-10 SS -'82 TRANS AM WS7 HT 5.0L TH350 2400 stall blue/blue level III PMD cloth PG hood -'85 Elky SS 310ci 2004r fully restored 2008 -'88 buick century estate wagon 3800 4t40e, 91 s-10 2wd 4.3L, 96 taurus, '97 cavalier RS 2.2L, 5sd -'05 18ft car trailer, 98 achieva, 98 cherokee,
randy78 is offline   Reply With Quote
Old 06-17-2008, 10:08 PM   #4
jason235744
hey guys great ideas , i checked all grounds , ones above starter and everthing that runs to a ground from computer, also i traced wires to tps and a/c cycle switch they are the same , "5v" power from computer, does not make a difference if a/c is on or off, thanks for replys guys. i assure you guys i will not quit until i find problem, love the car , it still looks and drives like new , i will be sure to post fix , after repair is made!!
