Go Back   Automotive Forums .com Car Chat > Jeep > Liberty
Old 06-26-2008, 01:54 AM   #1
hosscarl
02 Jeep Liberty heater-a/c electrical problem
The connection to the heater-a/c blower has overheated and burnt the insulation from the wiring. The pin connection is oxidized badly. I spoke with several parts houses and the Jeep Dealer, they all said this part is not available. Has anyone had this problem or have any suggestions as to a repair?
hosscarl is offline   Reply With Quote
Old 07-01-2008, 02:22 PM   #2
DAB77
Re: 02 Jeep Liberty heater-a/c electrical problem
If it is the power wire at the motor, you could try cleaning the pin and solder the wire to it. Make sure you insulate it well afterward. This is the only idea I have if the correct connector is not available.
DAB77 is offline   Reply With Quote
Old 07-01-2008, 10:59 PM   #3
hosscarl
Thanks, DAB77
I thought about that but the pins are recessed in a plastic socket and would be difficult to reach. I found a party in Texas that had a harness from a Jeep. It should be here soon. I hope this will solve my problem. Thanks again.
