2000 Blazer fuel pump help please!!!!
I am getting ready to replace the fuel pump on a 4 door 4x4 LT. Is there a secret on how to remove the fuel lines from the fuel pump that is in the tank?The ones on mine are not like threaded nuts but seem to be plastic and "factory attached" to the lines. Also is it necessary to replace the electric connections like the aftermarket stores suggest? Any insight and any other tips would be greatly appreciated. Thank You!!
Re: 2000 Blazer fuel pump help please!!!!
The other lines where rusted.
When I did my fuel pump, I cut the metal lines. Got some high pressure fuel lines at auto zone for 10 bucks, some hose clamps. And with a small screw driver I re opened the hole on the metal lines. Talking about the lines behind the left rear tire for the fuel pump wires. ground power etc. If they look fine keep em. and maybe clean down where the ground wire goes with some sand paper. I would also replase the fuel filter snice your putting in a brand new fuel pump. Other wise it would be pointless to do the pump |
Never never cut an splice them lines. It is a hiigh pressure fuel system capable of producing 105 lbs of full pressure. Running pressure is 60-66 lbs. Rubber fuel line and clamps are only a fire hazard. MT
The fuel line are just unsnap and pull. The center vent line is usually a pinch type release. Pinch on the biggest part of it and pull of. And make sure you unplug the tank vent on end of tank or it will brak off vent fitting If the connector is burnt or corroded replace it. Do not use the aftermarket pumps like airtex wonder if they are going to pump pressure. Only replace with the Ac-delco/Delphi fuel pump. Some modules will require a different wiring plug. Check your fuel pump application for a new/different wiring plug.
Go to Autozone and buy the "fuel line connector release tool" - I use the metal one- slips in behind the quick connect- to release the connection
Automotive A/C Engineer with: '99 IH 4700 Toy Hauler (2) '95 GEO Prizms both maroon '99 GMC Yukon '95 Chev 3500, 454 Dually Crew Cab- 145k miles- Wife's Camel trailer puller. '94 Astro- 370k miles '94 Firebird Formula- 5.7L 180k miles- gone- '92 Chevy Lumina Van 3.8L 264k '86 GMC S-15 - 2.8L 154k '87 Buick Park Ave . 187k '86 Buick Park Ave 3.8L 199k miles- gone '77 Chevy Vega- 2.5L 175k miles gone but not forgotten '68 Camaro 396 4 spd RS/SS -72k miles- |
Iv never had a problem, been driving it around like that for 2 years now. As my DD. but you are right
