Go Back   Automotive Forums .com Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Old 06-12-2008, 11:35 PM   #1
ruffd
1986 GT aircon problem
Help!
I am troubleshooting the AC in my minty GT with a Haynes wiring diagram.
The fuses are fine.
The electrical connector to the accumulator is obvious, as is the connector to the compressor clutch and all are intact. The wires for both disappear into the harness and must connect somewhere to the clutch cycling pressure switch or relay of sorts.
I may not be using the right terms, but you get the idea.
Any thoughts would be Greatly appreciated.
It's getting Hot out there!
Dale
ruffd is offline   Reply With Quote
Old 06-14-2008, 02:57 AM   #2
351wStang
351wStang's Avatar
Re: 1986 GT aircon problem
Do you your the compressor clutch kick in? You may just need a recharge. What is the actual problem?
1969 Cougar
357w & TKO - 475hp
351wStang is offline   Reply With Quote
