Go Back   Automotive Forums Car Chat > Chevrolet > Astro > M Bodies
Old 06-04-2008, 10:14 PM
ohagen383 ohagen383 is offline
Obd Ii Code
I have a 98 astro
and the tranny has been shifting rough, I got the code P0751
Shift A CKT PERFORMANCE Solenoid stuck off.
What solenoid is it and where is is located
and any suggetions on how I need to do the repair
thanks
Old 06-04-2008, 10:34 PM
old_master's Avatar
old_master old_master is offline
Advisor/Moderator
Re: Obd Ii Code
The transmission oil pan must be removed to access the shift solenoids and wire harness connections. Are you experiencing a harsh or delayed 1-2 shift?
Old 06-05-2008, 06:50 AM
Re: OBD II Code
Yes 1st to 2nd gear is very harsh, the shifts are normal in all the other gears
Old 06-05-2008, 07:48 PM
old_master's Avatar
Advisor/Moderator
Re: Obd Ii Code
When was the transmission fluid and filter last changed? It should be done every 36,000 miles. A very common problem is the 1-2 shift valve will bind in its bore in the valve body. If changing the fluid and filter doesn't improve the 1-2 shift, find a transmission shop that's familiar with the 4L60E transmission. Ask them if they are familiar with the repair procedure. GM is aware of the issue and they have a technical service bulletin addressing it.
