Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 08-19-2007, 01:44 PM
Arrowshooter Arrowshooter is offline
Unhappy Camshaft Timing Mark?
My sons 96 Ranger with 2.3 broke the timing belt on the highway. After replacement the truck will not start. While we were in there I noted that there are two marks on the cam pulley, a diamond and an arrow. We used the diamond because someone had put a white mark on the gear there. Is this correct. We checked for TDC by watching the exhaust valve cycle up and then then watched for the piston to come back up again. Also, does the second drive pulley do anything other than drive the oil pump? I figured that this truck does not have a distributor, so there should be no other connection. And lastly, could there still be bent valves even though this is supposed to be a "non-interference" motor? Thanks.
Old 08-19-2007, 10:21 PM
Smile Re: Camshaft Timing Mark?
Never mind, got it. Triangle Triangle, Diamond Diamond.
Old 05-09-2008, 11:10 AM
gman32234@netzero. gman32234@netzero. is offline
What do you mean by triangle triangle/diamond diamond. I am having the same confusion.
Old 05-14-2008, 08:30 PM
Jacfourteen Jacfourteen is offline
Yeah they are a pain my 94 broke 3 belts in the 140,000 miles I put on it. All three gears need to be in proper spots because the middle pully drives the cam sensor.
99 Explorer (my daily driver)
-2" lift, 31" tires
-Magnaflow muffler
-7" Touch screen DVD stereo
-12" drop down LCD monitor
02 Mustang Convertible (wife's)
-K&N Filter
-Flowmaster 50
68 GMC (project)
-300 HP 350
Old 05-24-2008, 08:13 PM
comp comp is offline
my dads 99 has 250k on the original belt is it going to be the same swap ????? it is a sohc 4
Old 05-25-2008, 02:18 PM
yeah i think it the same evoen though it is probably a 2.5. The belt isn't actually that hard to change, it's just a matter of knowing how to allign everything, the fact that yours is still intact will make it alot easier because you can turn it until the marks line up and then just change the belt.
-2" lift, 31" tires
-Magnaflow muffler
-K&N Filter
-Flowmaster 50
68 GMC (project)
-300 HP 350
Old 05-25-2008, 02:24 PM
intact so far ,,250K is crazy
