96 v-6 s-10 ss tranny help
i need to replace the transmission in my 96 v-6 s-10 ss and i need to know what other years and models of chevys have the same transmission any help would be appreciated
Re: 96 v-6 s-10 ss tranny help
Auto or std?
2 or 4W drive? What is bad on yours? This link may help. http://72.19.213.157/files/4L60ERemoval.html But I think it is more on a 4W auto transmission. If you are going used the bone yard should have a interchange book. Some not many years will interchange. Always check a good interchange book. MT
its a 2wd automatic transmission
i dont think that the tranny has completely went bad cuz it gave no warning signs. no slipping or anything like that was driving just fine one minute then it was just like i somebody put it in nuetral. however im no car expert and i know even less about transmissions so if anyone can tell me what if anything else it might be i would greatly appreciate it thank you
bobbydigital |
It could be any number of things, from a blown fuse to a failed pump. I had one "rebuild" which consisted of installing the pressure relief valve back into the pump (through the pan) and installing a new snap ring.
In short, more information and a little diagnosis is necessary. You can connect a pressure gauge to the test port on the left (driver) side of the transmission and read pressures in the various ranges. The gauge should be able to withstand 250 PSI or higher.
