Old 04-26-2008, 05:41 PM   #1
davesink
How do I reconnect the battery cable?
I installed a new radio in my '95 Lumina. In order to do that I disconnected the negative battery cable which was a real PITA thanks to the GM side terminals and lack of clearance to remove the bolts. The cable wouldn't simply slip off, so I had to remove the bolt with a tiny wrench but now that the radio is installed, I can't seem to reconnect the cable. I tried replacing the bolt and slipping the cable over it and I tried pushing the bolt through the hole in the cable and wrenching it on that way, but the threads are too short and the way it's configured, it's nearly impossible to get a decent angle on it. If I can't reconnect the cable, I guess I'll try using electrical tape to connect it enough to get it to a mechanic, but I'd really like to finish the job myself. Has anyone had any luck doing this and if so, how?? Thanks very much for any and all replies.
davesink is offline   Reply With Quote
Old 04-26-2008, 08:44 PM   #2
maxwedge
A990 racer
Re: How do I reconnect the battery cable?
Welcome to AF. Use a 5/16 or 8mm socket on a long 1/4 in drive extension, this will give you good access and you can apply pressure and turn the ratchet with the clearance.
Old 04-27-2008, 11:20 PM   #3
Bearwulf
Bearwulf's Avatar
Remove air cleaner housing to gain room.
Bearwulf, the "howling Grizzly" of the north.
MONOTONY is the worst driving hazard, so SHUT-UP when I'm driving.
97-Lumina LS
1891Argentine 7.65 with scope!
Bearwulf is offline   Reply With Quote
