Go Back   Automotive Forums .com Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 03-15-2008, 01:58 PM   #1
spyder52
94 Camry xle transmission problem
Hi,
My wife was preparing to merge onto the freeway and all of a sudden the car had a hard time moving. It had just enough power to pull over. No matter what gear she placed the car in it would just reve real high and not budge. After a few minutes she was able make it home without incident. The next morning same problem. However, reverse seemed to work. We were able to get the car back to the house. After that the car would not budge no matter what gear it was in, and no matter how much gas we gave it. Will we need to replace the tranny? I'm hoping not. Any help would be greatly appreciated.
Thanks.
Wayne
spyder52 is offline   Reply With Quote
Old 03-15-2008, 02:29 PM   #2
Mike Gerber
AF -Advisor
Re: 94 Camry elx transmission problem
You will need to supply more information about the car. What engine; I4 or V6? How many miles on the car? What if any maintainance has been done to the car, especially recently?
Mike
Mike Gerber is offline   Reply With Quote
Old 03-15-2008, 03:03 PM   #3
spyder52
Mike
Hi Mike,
Engine is a V6, miles 126K, tune up and oil leak repair (gasket replaced) in Oct 07. I just went out and started the car up. Engine lite stays on. Car is able to move when in reverse with effort but not in drive or any lower gear. Thanks for any help you may provide.
Wayne
Old 03-15-2008, 04:00 PM   #4
Mike Gerber
AF -Advisor
"Engine lite stays on."
If by this you mean the "check engine light", then the first thing to do would be to read the code. The manual posted at the top of this forum will give you the procedure and what the codes means. All you will need to do this is the procedure from the manaul and a piece of wire.
Mike
Old 03-15-2008, 05:55 PM   #5
spyder52
Mike
I do not see a manual at the top of this forum. Could you please supply the exact location of the manual. Thanks.
Wayne
Old 03-15-2008, 07:53 PM   #6
Brian R.
Resident Chemist
Brian R.'s Avatar
Send a message via Yahoo to Brian R.
You will need a code reader to read the codes in that car. 1994 V6 Camrys were OBDII compliant, not OBDI. The procedure in the FAQ will not work.
The manual is linked in the thread entitled "Factory Service Manuals!".
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Brian R. is offline   Reply With Quote
Old 03-16-2008, 03:13 PM   #7
spyder52
Thanks Brian. I'll take it to a shop and have it checked out. Hopefully I will not have to replace the transmission.
wayne
Old 03-16-2008, 05:46 PM   #8
Mike Gerber
AF -Advisor
Brian,
I thought 94 and 95 V6 cars had both OBD1 and OBD2 connectors, and codes could be read either way. It is probably easier for him to just drive the car to a place like Autozone (if it is drivable) and get the code read there. We'll hope for him it's something simple.
Mike
Old 03-16-2008, 05:58 PM   #9
Brian R.
Resident Chemist
Brian R.'s Avatar
They won't read '94 or '95 cars at Autozone. We've been through that a few times. At least at the ones others have tried. No hard in trying though.
I think it is impossible for a car to be both OBDI and OBDII compliant. Different computers. If you check out the '94 manual for the V6 SFI, you will see only OBDII troubleshooting procedures.
Old 03-16-2008, 07:33 PM   #10
Mike Gerber
AF -Advisor
Thanks for the info. I stand corrected. My 94 is the I4 so personally I never paid much attention to the 94 and 95 V6's.
Mike
