Engine Mount Problem on V6 3.0L 1MZFE
After replacing TB I have a low frequency rumbling vibration which sounds like an exhaust leak. Only occurs when car is in gear, much worse when cold.
Had wife hold foot on brake and put trans in R. Gave a few revs and engine looked like it wanted to jump out with rear side (closest to firewall) lifting up seemingly unrestrained. Looks like rear engine mount is shot. Don't understand connection between TB and this problem but guess that removing crank pulley bolt by bumping engine put the final blow on an already deteriorating bushing. Or, maybe just a coincidence. In searching this and other forums it appears the rear mount is a mother to replace requiring disconnecting steering column and jacking engine. Has anyone replace rear mount? Any tips on how to? Thanks. |
Re: Engine Mount Problem on V6 3.0L 1MZFE
Removing the front mount is much easier. Remove bottom splash guard, top radiator hose (drain out a little coolant first) and electric cooling fan. Remove main connecting bolt, two bracket hold down nuts and one bracket hold down bolt. Jack up engine a couple inchs and it comes right out. My front mount looks ok to me but I am going to replace it anyway as it seems like good practice to replace front & rear mounts in pairs. |
Though about removing the exhaust for better access but I didn't want to be like the guy on the Camry forum that spent 3 days pounding, spraying with penetrating oil and heating with a torch to remove axle. What's really funny is the Repair Manual which says all you have to do is remove snap ring and bearing retaining bolt and pull out the axle. Guess what? The joke is on me! |
Some Toyota dealers still carry the rubber bushing listing at about $54. You can get an aftermarket for half that price. The problem is the major difficulty in removing the bushing from the cast iron bracket. In fact, my two favorite on-line Toyota parts suppliers (Irontoad and DTS) no longer carry the rubber bushing separately. You have to buy the bracket/bushing assembly for about $100 plus S&H (does not include the axle support bearing). The second biggest problem is removing the bracket when the RH axle support bearing is seized in the mount bracket. I plan to solve this problem by hacksawing the locating pins allowing the axle/bracket assemply to slide out laterally. It should be much easier to remove the bracket from the axle off the vehicle. I'm not sure if the bracket will slide out w/o removing the PS pump-I'll let you know. I read another post which said yoou have to disconnect the steering coupling and lower the sub-frame to provide clearance. I'm hoping I don't have to do that. I'll let you know the outcome. PS. Don't try to cast a bushing from 3M Windo Weld. It is a one part moisture cured polyurethane which takes forever to cure! |
