Go Back   Automotive Forums .com Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Old 04-10-2008, 08:57 PM   #1
Michigan Rick
Mustang II brake problem
I am just getting my vehicle out for spring. The brake pedal goes to the floor. So I filled the master and bled all lines and got pedal pressure. I start the vehicle and the pedal goes away. A friend says I need a new booster. He says to suck on vacuum line to see if it holds pressure. It does unless I move the rod that goes into the master....than it leaks air . Is it the booster leaking or ???
What is the correct amount the rod from booster goes into master.? Should it be touching inside master or ???
Rick
Michigan Rick is offline   Reply With Quote
Old 04-11-2008, 01:21 AM   #2
351wStang
351wStang's Avatar
Re: Mustang II brake problem
I suggest replacing the master cylinder and booster together.
1969 Cougar
357w & TKO - 475hp
351wStang is offline   Reply With Quote
