Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Exterior and Wheels
Exterior and Wheels This is the place for all exterior wheel modifcations.
Old 03-02-2008, 02:55 PM
Trueeclipse's Avatar
Trueeclipse Trueeclipse is offline
bent my rim in 2 spots =[ can i still use it?
I ran over a pot whole and bent the front lip and the back lip of my rim.
When I check the tire p ressure it seems normal and doesnt seem to be leaking,
is there a hazard involved, what will happen to this rim over time should I have to order a new one??!
http://img.auctiva.com/imgdata/1/3/0...11134598_o.jpg
there is a link to how bad of a bend it is..
thank you guys
also do you know of any companies that melt down rims in exchange for money, if so please give me their contact info!
T R U E E C L I P S E
1996 MITSU. SPYDER ECLIPSE
[email protected]
http://www.cardomain.com/ride/653950
Old 03-02-2008, 03:01 PM
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
Re: bent my rim in 2 spots =[ can i still use it?
rims look ok! just be carefull with checking the pressure at first, make sure its still holding. and as for the long term, as long as you dont feel/here viberations at about 75-80mph, then you should be ok to continue to drive on it!
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Just take it to a tire/wheel shop and they should be able to bend that back out. It doesn't look too bad. Should be fixable, and probably not too too much $$$
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 03-02-2008, 03:13 PM
i just dont want the tire to blow on the high way and then have to change it or cause any accident,
Can anyone recommend a wheel bending shop...?
[email protected]
Old 03-02-2008, 03:29 PM
lets say I was driving on the high way and something happend, would the tire simply just loose air and become flat or would it fly off or what would happen..
what is the danger level at say 45- 80mph...
[email protected]
Old 03-02-2008, 03:57 PM
Black99GST's Avatar
lol if the tire is holding pressure, then drive to anyware (lambs, firestone, etc) and they will fix the rim. aslong as the tire holds pressure, and doesnt shake from 65-80mph, then i would say you are prefectly fine! worst case, the wheel is off balance and you NEED to get it bent back... (been their, done this!)
Old 03-02-2008, 08:12 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Just take it to a shop and see if they can fix it. It probably wont hurt to drive on it but I wouldn't ride on it to long with out getting it fixed.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 03-03-2008, 08:17 AM
JoeShmoe's Avatar
JoeShmoe JoeShmoe is offline
Send a message via AIM to JoeShmoe
Should be fine, your not gonna lost control if your tire gets flat. If you're really that concerned about it I would recommend you make sure that tire is on the rear as opposed to the front.
'98 Contuor SE, 2.5 V6 Auto Silver
'08 Altima 2.5S, Auto Super Black
Old 03-03-2008, 11:13 AM
called fire stone and belle tire
fire stone said they cant do anything unless it is a steel rim and belle tire says they cant do anything...
maybe I will have the the rim melted down and get 10 bux toward a new one...
any other ideas people.
[email protected]
Old 03-03-2008, 11:24 AM
Black99GST's Avatar
try lambs... thats B/S! your local mazda dealer will do it... i had my rim fixed their... the rim on the infinity...
