| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
My clutch pedal has no resistance
My clutch pedal has no resistance at all !!?!?
i own a 2.4 liter 1996 mitsubishi spyder eclipse non turbo is the clutch system hydrolic or no? what could be wrong?
T R U E E C L I P S E 1996 MITSU. SPYDER ECLIPSE [email protected] http://www.cardomain.com/ride/653950
Re: My clutch pedal has no resistance
Yes the clutch is hydrolic. Check your resivoir to see if there is fluid in it. Then find where the leak is at.
98 Eclipse GS Turbo Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio 1981 Chevy Scottsdale 1987 Nissan 300zx - Chump Car 2001 BMW 325i - DD |
I will try this tommorow and let you know how it goes.
I looked in the resovoir today and the liquid was frozen!!!!! what does that mean
Brake fluid doesn't freeze, must be water in there or something. I would recommend changing that shit.
Hmm frozen brake fluid means you need more anti freeze in it...=)
Seems like someone didn't use the right fluid on last fill up. I've been in one of the most extreme places where -60 comes and goes on a whim and never seen brake fluid freeze :/ I would suggest draining , replace the seals ( master / slave ) as the freezing water or whatever was jammed in there may have ruined them. Easy fix shouldn't take more than an hour to do and you should regain pressure. Then again , when I had my tranny built I thought it was weird that the clutch pedal was softer to press in than the gas pedal but I get perfect shifts everytime.
2004 Mazda 6i 1997 Tahoe |
ok so we tried bleeding it but nothing came out...
maybe we did it wrong, can someone provide step by step instructions on how to bleed clutch for a 1996 mitsubishi 2.4 L non turbo eclipse. thanks
You need to totally drain out all the fluid. Take the bleeder screw completely out and let everything drain out. Then refill the system with brake fluid and bleed the system.
When you "bleed" the brake lines, all your doing is removing the air from the system. Like Silver said you need to remove all of the fluid from the system. I would even drain everything out then let some brake run through it just to clean out all of the old crap. Then reinstall the bleeder nipple and top off system then bleed out the air.
not to mention your master cylinder is probably trash... check the inside of your car, on the floor by the clutch peddle, if theirs fluid their (on the carpet and such) its time to replce that little bugger
1995 Mitsubishi Eclipse GS-T 5-speed Intake Cone Filter, HKS Blow Off Valve, GReddy Turbo Timer, Eibach Coil Springs, Tokico Shocks, Apex’I Catback Exhaust System (2.5”), Short Shifter, 17x7” Premium Aluminum Rims wrapped in General Exclaim UHP Tires, Indiglow Gauges, and Aftermarket Alarm with Keyless Entry (2 keys, each with remotes) |
