Go Back   Automotive Forums .com Car Chat > Pontiac > Grand AM
Old 02-10-2008, 03:38 AM   #1
elgueaga
anyone have thier timing chain replaced by a mechanic
If so how much did the labor cost and how long will it take to have it replaced im pretty sure i need mine changed soon noise is coming from the engine in the timing chain area I have a 2002 grand am 2.2 ecotec with 95000 miles on it
elgueaga is offline   Reply With Quote
Old 02-11-2008, 05:17 PM   #2
J-Ri
J-Ri's Avatar
Re: anyone have thier timing chain replaced by a mechanic
Have a mechanic diagnose the sound first. 95K is very low miles for a timing chain problem. Even if it is in that area, it may not be the chain causing the noise, so a new one won't fix it. If you havn't already, remove the serpentine belt and see if the noise goes away.
Can't help with time/cost... most ecotecs aren't in need of a timing chain yet.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
J-Ri is offline   Reply With Quote
Old 02-17-2008, 08:27 PM   #3
grave digger
It is too soon for a timing chain replacement, but worn timing chain guides will start to make a little noise in these engines. This noise is harmless, but annoying. I had my chain replaced for this same type of noise, the mechanic said that the chain and the tensioner were both good, but the guides were worn to a point that a noise could be heard. I only had the chain and tensioner replaced because everything was all taken apart. It cost $750.00 so it is a good idea to wait on this one.
grave digger is offline   Reply With Quote
Old 02-18-2008, 01:49 AM   #4
elgueaga
well I hope you guys are right id hate to be driving and have ny timing chain break. well thanks for the info I just thought the timing chain wear was accellerated in my car due to me lending my car to my sis and it over heating on her
Old 02-19-2008, 05:59 PM   #5
J-Ri
J-Ri's Avatar
I've got almost 190,000 miles on my 2.4l, I don't think yours will break at 95,000
How bad did it overheat? It's possible there's internal engine damage.
Old 02-22-2008, 02:07 AM   #6
elgueaga
well it was bad enough for a engine mount bolt to break later that day . but the overheating happenned at 60,000 miles about a year and 2 months ago
