Go Back   Automotive Forums .com Car Chat > Cadillac > Eldorado
Old 02-23-2008, 10:05 PM   #1
gugster
1985 eldorado heater core
how do I replace it? is it under dash board ...just some help please..
gugster is offline   Reply With Quote
Old 02-23-2008, 10:40 PM   #2
caddydaddy
Re: 1985 eldorado heater core
They're usually behind the glove box. But without a service manual, I have no way of telling you! Check www.cadillacforums.com
2000 Cadillac STS
2005 Cadillac Escalade
2008 Triumph Sprint ST 1050 ABS
caddydaddy is offline   Reply With Quote
Old 03-13-2008, 08:57 PM   #3
DAB77
From 1985 MOTOR A/C & Heater Manual
Remove instrument panel. Remove defroster nozzle by removing 4 screws at cowl and screw at heater case.
Disconnect vacuum lines to programmer and actuators.
Disconnect harness leads and air mix door linkage at programmer.
From engine compartment, remove 4 heater case to cowl retaining nuts.
From under the instrument panel, remove heater case to cowl retaining screw. Remove heater case.
Remove 4 case to core retaining screws and heater core.
Reverse procedure to install.
Hope this helps
DAB77 is offline   Reply With Quote
