Go Back   Automotive Forums .com Car Chat > Pontiac > Grand AM
Old 02-19-2008, 07:29 PM   #1
jpolasko
serpentine belt tensioner
I have a 95 Pontiac Grand Am . I'm trying to remove the tensioner but cant get to the nut .The spring inside has pushed the tensioner out which makes it even harder to get at the nut. What can I do to get this thing off?
jpolasko is offline   Reply With Quote
Old 02-19-2008, 08:15 PM   #2
xeroinfinity
out saving the world
xeroinfinity's Avatar
Re: serpentine belt tensioner
Welcome to AF.
Your post has been moved to the proper forum section.
What size engine ?
1999 Grand Am SS 3.4 OHV
xeroinfinity is offline   Reply With Quote
Old 02-20-2008, 08:22 AM   #3
jpolasko
95 grand Am Tensioner
Tensioner is poped uot.Almost impossible to get to the bolt what's the best way to take off the tensioner?
Old 02-20-2008, 09:55 AM   #4
brcidd
brcidd's Avatar
Re: 95 grand Am Tensioner
Which engine?- there are three choices I believe-- or give us the 8th digit of your VIN....
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
brcidd is offline   Reply With Quote
Old 02-20-2008, 11:51 AM   #5
xeroinfinity
jpolasko, no need to post duplicate threads.
I have merged your two into one.
If you cant get a wrench on the tensioner bolt, then the entire braket that's bolted to the engine might have to be removed from the motor.
Sounds like the tensioner is busted anyway.
Old 02-20-2008, 03:17 PM   #6
jpolasko
sorry we never did this before so I didn't mean to post it twice. Its a 3.1 SFI engine.
Old 02-20-2008, 05:55 PM   #7
xeroinfinity
Thats ok.
You might be able toget better access through the pass side wheel well. Removing the wheel and inner fender cover(plastic parts).
Old 02-20-2008, 06:23 PM   #8
J-Ri
J-Ri's Avatar
Isn't that bracket held on by three bolts, one of them being the tensioner bolt?
There are so many different depths of sockets, I'm sure you can get something that will fit it even if you have to put the socket on by itself and use vise-grips to turn it. Since you said the spring pushed out, that probably means there's no tension on it. If there's not, try cutting the spring and pushing the tensioner back into place to get at the bolt if you can't find anything to get it off.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
J-Ri is offline   Reply With Quote
