Old 02-16-2008, 10:23 AM   #1
laz0rus
92 Lumina overheating
Very recent problem. I'm going to be replacing the thermostat, and also the fan motor. Anything special I should look out for? From what I've seen and heard, the thermostat replacement is a lot more involved than on a lot of other cars.
laz0rus is offline   Reply With Quote
Old 02-16-2008, 12:03 PM   #2
j cAT
Re: 92 Lumina overheating
if engine has been overheating pressure check for leaks first..if it is determined that it is dirty/sludged you will need chemicals to clean system.. when adding coolant if you donot drain engine completly find coolant capacity and calculate the proper amount of antifreeze to use...when flushing coolant system do so with thermostat removed......
Old 02-17-2008, 02:41 AM   #3
Bearwulf
Bearwulf's Avatar
What engine?
Bearwulf, the "howling Grizzly" of the north.
MONOTONY is the worst driving hazard, so SHUT-UP when I'm driving.
97-Lumina LS
1891Argentine 7.65 with scope!
Bearwulf is offline   Reply With Quote
