del sol question?
i have a del sol and ive seen del sols put the cd/flip out monitor in the top vents on the dash i was just wondering how hard and what it takes to do that?
95 Civic EX H&R sport springs KYB AGX Struts Energy Suspension Poly Bushings 15" black VSR's on nitto NT450 not-so extreme performance 205/50/15 CAI http://www.cardomain.com/ride/2489240/1 |
NA is Best!
Re: del sol question?
I've never seen that but I'd imagine it's not simple. You'd probably need to extend the harness, make a trim ring, make supports for the unit itself and block off the opening in the air duct. I think that would look dumb anyway. You have any pics of this?
Honda GODDESS/Global Mod
Orrrr you could just put it, you know, where it belongs, in the radio section?
It's a PITA fitting things in the del Sol dash.. it's a very shallow dash, compared to other dashes, and you would have to remove all your air ducting to fit a radio there. Just put it in the radio spot. |
i already have a radio in the RIGHT spot. i was wanting to put a flipout in my car but if i put it where the radio goes it hits and doesnt open all the way
I've never had a problem with a flipout in the stock radio location. It can be a bit of a pain cause you have to pull the shifter back into 2nd or 4th or R, but I usually leave my car in 2 when it's parked uphill or flat, and R when it's parked downhill anyways. If you are unfortunate enough to have an auto, it should be out of the way by D4. And once it flips up, you have nothing to worry about.
Get a flip out that fits then. You'll miss the vents.
dSoc member #67 1995 Honda del Sol EG2 VTEC Milano Red. RIP :crook: 1994 Honda del Sol EG1 S-full VTEC conversion. Buy my Del Sol parts!! |
#7 | |
i have a flip out screen, what i did was made little spacers for the screws that mount the unit... it pulled out the unit and has enough clearance so that the screen will flip a lil past vertical level.
